vette tranny... different??
Old Nov 8, 2002 | 08:59 PM
FstBrd6point3's Avatar
I picked up a 700r4 from a "87 vette" and got it home and while comparing it to my 700 out of an 87 firebird, I noticed the tailhousing on the back of the tranny is different.... then I noticed the BIG difference, the case casting doesnt even have holes for the transmission mount, and the tailshaft doesnt have holes in it for the tourque arm. Am I missing something, or do I have a completely useless tranny on my hands?
Old Nov 9, 2002 | 12:18 AM
wuter's Avatar
you can always try to swap the tailshaft, its only held on with 4 bolts, while its off you might as well swap the speedo gears.
Old Nov 9, 2002 | 08:38 AM
the speedo gear was easy to do, I did that already, but the place where the mount screws in on my fbird tranny isnt even there on the corvette one..... that is my main concern.... at first I thought it might be a place that could be put on or off with the tail, but it is a part of the casting.....
Old Nov 9, 2002 | 01:43 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
As already stated, you need to just swap the old tail shaft from the old tranny to the vette tranny if you still have it. And don't forget that it you do run the F-body tail shaft, you need to make sure that you hook the speedo drive gear to the most forward hole on the output shaft.
Old Nov 9, 2002 | 02:32 PM
Pro Built Automatics's Avatar
It is missing the cross member mount holes, it is apx. 1" shorter in length. It is not going to interchange.
Old Nov 10, 2002 | 12:46 AM
well that really sucks nuts..... I guess it is time to try and find a not so pricy t5, cuz if I am going to be buying a tranny again, to hell if it is going to be auto, I need that thrird petal feel.... no hard feeling pro, I bought the shift kit for this vette tranny from you.....****
Old Nov 10, 2002 | 10:13 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
why don't you just get an F-body tail shaft?
Old Jan 17, 2004 | 02:06 AM
25THRSS's Avatar
Is there any model 700r4 tailhousing that doesn't have the tq arm provision, but has provisions to mount to the stock crossmember?
Old Jan 17, 2004 | 06:12 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
out of a caprice
or 2 wheel drive truck
Old Jan 17, 2004 | 06:13 PM
whoops, read it wrong, the vette tranny will not work with a different tailhousing because it is indeed shorter and the holes for the tranny mount are on the case itself
Old Jan 19, 2004 | 12:32 AM
25THRSS's Avatar
Originally posted by 1991tealRSt-topGuy
out of a caprice
internally they are exactly the same as the f body?
Old Jan 19, 2004 | 06:52 AM
governors are prolly different, thats about it
Old Jan 20, 2004 | 04:42 AM
Different valve body & governor.
Old Jan 20, 2004 | 04:46 AM
25THRSS's Avatar
Forgive my ignorance, but i'm not too fimiliar with valve bodies. I assume this means that they are not interchangable, and the only tailshaft that can be used on a third gen would be the one that originally came with the car?
FormulasOnly
Jul 23, 2018 08:47 AM
BDR
Nov 7, 2015 03:05 PM
R13_Braz
Sep 18, 2015 05:00 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
