axle code help
Old Nov 14, 2002 | 04:19 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
axle code help
hey guys i have a 10 bolt rear sittin in my yeard that i took out and put a 9-bolt in cause i wunted the posi, well anyways today i went out to have a look at the 10-bolt and i took the numbers off it and looked in my haynes manul and it said it was a 3:23 posi rear from 88-89. now i don;t think it was a posi cause it never even did a posi burn out one or any signs of a posi thats warn out. now here are the numbers,6HJ Z 1841 also is this a 28 spline rear? thanks
Old Nov 14, 2002 | 04:43 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
my book says the same. you could take the cover off to see if its a posi. i think that 89 was the year it could be either one a 26 or 28
Old Nov 14, 2002 | 08:44 PM
Car: 89 Formula
Engine: Carbed 5.7
how can i tell if it was a posi by poping the cover
Old Nov 14, 2002 | 09:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Open diff just has gears. A posi will have clutches.
I see 6HJ as 1988 and 1989. 3.23 gears, Posi. Personally I don't think it will have 28 spline axles.
Old Nov 14, 2002 | 09:34 PM
craig's Avatar
Car: 86 camaro
well from what little i know about them a posi would have the springs and clutches in there. a onelegger would have just the spider gears. look in a jegs or summit or go to auburns website and see if thats what you have.
Old Nov 15, 2002 | 05:28 AM
MdFormula350's Avatar
my 1991 formula has a 10 bolts rear with 3.23 posi..
it has alot more going on inside than an open rear...
6speedIROC
16
Mar 15, 2023 08:33 PM
db057
Jan 10, 2020 08:55 PM
Numbah-1
Sep 20, 2015 09:31 AM
dbrochard
Sep 7, 2015 09:41 AM
rudolphschenker
Sep 4, 2015 02:41 AM
