"klunking" noise from axle
Old Nov 17, 2002 | 01:31 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I get a klunking noise from the driver side of my axle right near the drum when I go over the slightest bumps.. it started after I put on LCAs and a panhard rod. sounds just like I have a loose lug nut but I tightened the **** out of em and it doesnt help.
I took it to a race shop and the guy said that the free play of the axle was causing the flange to hit the housing. he said that something in the center section (I cant remember what he mentioned it was) was getting worn.
I have my old non posi axle that I could give them to fit with a posi and put in but I was just curious to see if anyone here has had a simmilar problem.
thanks
Old Nov 17, 2002 | 12:49 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Sure, it's not from underneath you, maybe a tranny mount problem.
Old Nov 17, 2002 | 02:06 PM
MdFormula350's Avatar
thats odd, so everything is tight and nothing is binding...
Old Nov 17, 2002 | 03:40 PM
nickyg's Avatar
Car: '91 TA Green
sounds like your trans mount. they are easy to replace cheap to
Old Nov 17, 2002 | 06:36 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: Moser 12 bolt, 4.11's 33 spline axl
If it started after you put new LCA's on its a good bet thats where the noise is coming from....aftermarket LCA's that have stiffer bushings (aluminum or urethane) tend to make quite a bit of noise...if they come equiped with zerk(grease) fittings, make sure you grease them liberally and quite often, that will make a big difference.
it could also be a loose or broken sway bar link that makes that sound, ive had that happen as well. I highly doubt that its coming from the end play in your axle.
my hotchkis lca's do that, which means its time to grease them again, and after i do that, no more noise.
oh ya, if you have an aftermarket panhard rod, make sure you grease that too if its equipped
Old Nov 17, 2002 | 08:48 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
the problem has been there for awhile and I greased the H*LL out of all the new bushings BUT--
do you really think it could be a sway bar bushing??
not an end link but the bushing
the guy at the dealership told me that it was worn.
BTW I know its not a tranny mount cause I have had that break before and replaced it with an energy susp.
The thing I cant figure out is if it was the sway bar then why would it klunk when I push and pull on the back of the car?
and it seems like the noise is unmistakably coming from behind the brake drum but I will double check the sway bar bushing
Thanks for the replies.
Old Nov 21, 2002 | 02:40 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I am still stumped as to why the axle tube is so loose.
I jacked up the axle finnaly and it is the axle tube.
it just moves in and out like 1/8 inch or less but makes this klunking noise. at the flange right behind the drum.
what is worn down in the center section that is allowing this axle play?
Old Nov 21, 2002 | 03:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
1/8" is about right.
It's probably either the upper shock mount broken, or the sway bar bracket loose.
Old Nov 21, 2002 | 05:06 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
thanks
Old Dec 30, 2002 | 04:54 AM
SIMON HOLTBY's Avatar
Was this problem ever fixed? I have a similar problem after fitting new LCA's and panhard rod
Simon
Old Dec 30, 2002 | 07:10 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
The problem was the axles had too much endplay all along and the stiffer LCA's just allowed me to hear the noise. I have a new rear and no more klunking...
Old Dec 31, 2002 | 12:29 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Wouldn't offset axle bearings fix that a lot cheaper than an R and R of the rear end?
Old Dec 31, 2002 | 09:40 AM
I got my problem sorted. I was convinced that it was axle endplay as when I jacked the car and pulled/pushed the wheel it seemed to make the same clonking sound and have too much play.
Turned out to be a loose bolt on the LCA. Even though I tightened all the bolts like hell. Yesterday I tried hitting the LCA with the palm of my hand near where they bolt onto the body and I heard a clonk. I used a spanner and another trolley jack to turn the end of the spanner to get it tight enough. I think I have read people sometimes need to fit a washer to take up the slack.
Anyway its great to get it fixed.
Simon
88 Camaro 350
Old Dec 31, 2002 | 08:56 PM
Camar92's Avatar
Car: 1986 IROC-Z
Engine: Vortec 350 with mild cam
Transmission: 700r4 Mild build
Axle/Gears: Stock
sounds like axle bearing
cheesehomer
Dec 31, 2015 08:48 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
