4th gen rear
Old Nov 18, 2002 | 10:51 PM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
4th gen rear
Im sure this has been asked a million times, and if it has im sorry, i checked the tech files and didnt see anything, So basically I can pick up a 10 bolt out of a 99 z28, it has posi which is basically why I want it because I have open diff on my rearend and it has a whole lot of miles. I have about 400 hp will a 10 bolt handle this? Is there anything I can do to make it stonger. Will it bolt up no problem or will there have to be things changed, thanks for the help
Old Nov 18, 2002 | 11:12 PM
87Formula4bbl's Avatar
Car: '87 Formula
I couldn't tell ya about whether the 10bolt will handle 400HP, but I am venturing to say that you should be fine with it, unless you tear on it consistently.
I just installed a 4th Gen. rear in mine, it's a snap. Mine was out of at least a 97+ camaro. The only difference was going from drum brakes to the disc brakes. You may need to upgrade your master cylinder/proportioning valve, do a search on it. I'm still researching for options on what I should do to improve the rear disc brake situation on mine.
Like I said, it should be a snap. Everything bolts right up!
Good luck!
Old Nov 18, 2002 | 11:30 PM
MdFormula350's Avatar
well a 99 z28 would have a ls1 right, they have alot of power and people upgrade those cars alot and havent had many rear end problems..
go for it, most likely way stronger than the factory 10 bolts on thirdgens..
Old Nov 18, 2002 | 11:36 PM
biff85ta's Avatar
Car: 04 Vette
87formula4bbl any problems with wheel and tire clearence on the back I have a set of newer formula 16`s but the offset is the same as yours.
Old Nov 20, 2002 | 12:14 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Except for the switch from 26 to 28 spline axles and 7.5 to 7.625 ring gear size (late 80's), 10 bolts are all the same strength from 1982 to 2002. The only stronger rears were the 9 bolts and the Firehawk dana 44.
Miles
Diff Solutions
www.9bolt.com
1992rs/ss
Jan 31, 2025 05:10 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
