Clutch Help
Old Nov 21, 2002 | 08:06 PM
Jay1986's Avatar
Clutch Help
Clutch Help ???
Here's the story I have a 86' Camaro 2.8 Liter V6, I changed the clutch (Pressuse plate, Clutch, Throwout bearing) I also had to change the Slave cylinder.. Now this is were I'm at now I can start the engine but there's a noise coming from the clutch and when I press the clutch pedal it get's worse, Can't change it into gears, and the middle console part shacks bad.. Can anyone help It's killing me I don't have a car.. Thanx Jay
(The Pressure plate is on the right way, all bolts are tight, throwout bearing in put on the shaft the right way, filled transmisson with gear oil, I think that covers it all)
Old Nov 21, 2002 | 08:14 PM
vortechLT1's Avatar
can you switch gears when the car isnt running?
Old Nov 23, 2002 | 09:36 PM
Nordbert's Avatar
Are you sure the disc has the "spring side" toward the pressure plate? If the flat side of the disc is toward the pressure plate,
the cushioning springs will drag on the heads of the flywheel bolts.
Old Nov 24, 2002 | 05:16 PM
Camarojohn82's Avatar
yea i can move it in and out of gears when its not running.. but it wont start anyway.. the pedal isnt hooked up b/c the linkage isnt in it
and im sure it's all installed properly
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
