I've got to change my tranny mount, AND both my motor muonts today. And, I think I can do the tranny mount, but what's the easiest way? If there is one. And, if this is on the wrong board, sorry, but how do you change the motor mounts? Thanks
both are pretty straight forward, jack up the engine or trans, unbolt the mount and replace. the clam shell motor mounts are a bit more to change out and harder than hell to get to.
when changing to tranny mount i help the tranny up with a jack that had a piece of wood over it.. then take down the crossmember and then you can get to/change the mount..
never did engine mounts yet..
Same thing with the motor mounts. Jack the engine up with a piece of wood so you don't harm anything. It's a pain, but posible, do only one at a time! for safety reasons. Good luck.
