View Poll Results: how many times did your t5 broke down??
once
71.43%
twice
14.29%
3 times
0%
4 times
0%
5 or more
14.29%
Voters: 7. You may not vote on this poll
t5 guys
Old Dec 11, 2002 | 02:09 AM
  #51
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
I'll let ya know when it breaks, I need to buy her and get her home first lol.
Old Dec 11, 2002 | 08:37 AM
  #52
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Need rebuild?
Guys,
I'm going to start rebuilding manual transmissions as a sideline to my day job.
I've built MANY gearboxes for roadracing cars that have to stand up to serious horsepower. These weren't T5s, but I have the experience. I built Transmissions for SCCA TransAm Series cars.
I'm just getting started, so email me and we can talk about a rebuild.
[edit: Oh yeah, I haven't broken a T5 yet]
Thanks,
Clem
Old Dec 11, 2002 | 10:42 AM
  #53
laiky's Avatar
when i did mine, it was pretty easy. The most important thing i did to make it simple was to lay the parts in order on a long table as i took them off the shafts . I bought a bearing and syncho kit as well as a replacement 3rd gear and countershaft. The most difficult part, if i remember correctly, was setting the preload. Its all in the manual. I think the only special took i needed was a dial indicator for the preload
Old Dec 11, 2002 | 01:32 PM
  #54
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Originally posted by 383backinblack
i blew up 2 in 2 different cars behind stock motors.....
You can't drive a manual trans.
anyone that claims a t5 is a good tranny is highly ignorant and uneducated....if they last its just luck and/or granny driving.
Consider me insulted. Consider you "ignorant and uneducated" on the subject of being able to make a manual tranny live.
there are alot of threads from the past that explain in detail the inherent weaknesses of the t5, if you do a search you'll find them.
What's your point?
Thank you drive through
Clem
Old Dec 11, 2002 | 01:36 PM
  #55
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Originally posted by AYMAN
come on guys we need more replies
Zero isn't an option.
I rebuilt mine for the hell of it. Truth to be told, I sold the previous one in perfect operating condition (1984 T/A box) and put in an 88 TBI 305 box.
Old Dec 12, 2002 | 01:37 PM
  #56
ZRated85355's Avatar
My attempts to blow the guts of my gear box all over the track have been unsuccesfull. I will continue my efforts and tell you when it finally gives in. Every one told me "it wont last a week" and that was 50+ passes at the track ago. I never take it easy and if i had the money to buy a pair of slicks i would launch it at 6000 to see light under the tires with a stock T5.
My transmission came from the factory in 85 mated to a 2.8 liter V6. 127,000 miles later i droped in a 355 dynoed at 425 hp. Now the tranny has 135,000 miles on it and never misses a gear.
For you who call that a bad transmision, shame on you.
Old Dec 14, 2002 | 08:38 AM
  #57
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I am gonna drop my tranny this weekend and I'll send
some pic of it
Old Dec 14, 2002 | 04:50 PM
  #58
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
ive done about a dozen 5k 2ND GEAR clutch dumps in my 91 WC T-5 and no clutch slippage or problems yet....although when i try to really powershift it it wont go into 2nd gear, so when i shift i just barely lift my foot off the floor so i fit doesnt go into gear i wont blow the motor lol
why wont it go into gear when i try to powershift?
it only does it sometimes
Old Dec 14, 2002 | 11:36 PM
  #59
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
sometimes when i powershift 2nd too it wont go in, only occasionly though, its weird because i never miss 3rd but sometime 2nd wont go in...
Old Dec 15, 2002 | 12:36 AM
  #60
Eightyninef's Avatar
my original T5 had a whiny 5th gear from the factory. GM replaced it at 6,000 miles, and it has been fine ever since. and I auto-x it and road couse it regulary, and it holds up fine.
It has 60,000 miles on it, and I'll get another 60,000 out of it no problem.
Old Dec 15, 2002 | 11:53 PM
  #61
BillD91RS's Avatar
Once
I had to get mine rebuilt two years ago and they replaced it just before I bought it.
Old May 20, 2003 | 04:33 PM
  #62
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
i blew a non wc to pieces behind a cammed lg4
ive had a wc one behind it and its been fine... LOTS of track passes on dr's
Steve
Old May 20, 2003 | 08:10 PM
  #63
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Clem
I second that. Power doesn't break tranny's, people do.
Old May 21, 2003 | 12:24 AM
  #64
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Most likely the 1-2 synchro is the problem. I'm going to have to rebuild mine soon here. My 1-2 and 3-4 synchros are about shot. I have to match rpms for it to go into gear smoothly. When I do rebuild it though, I'm going with the G-force kit. Does anybody know if that kit comes with synchros?
Old May 21, 2003 | 12:34 AM
  #65
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
My car was parked for 4 years because of the tranny - that and no one wanted to fix it. Has around 120,000 on it. Only prob I seen with it was some kinda flat needle-thrust washer was wasted. Everything else looked great...replaced it and been going ever since.
I had a problem with mine banging out of second too. I adjusted the clutch and that seemed to help.
But now there's something screwed up with my speedo. And if I drive the lower cable with a drill, the speedo works fine. I think the clip on the plastic worm gear inside the tranny fell off.
Oh, and I think my throwout bearing is shot possibly. Hear a grinding noise (only sometimes) when I push in the clutch.
And it leaks too.
I'm looking into an aftermarket tranny right now, or possibly just buying a G-Force T-5 tranny. Not sure yet.......
Old May 21, 2003 | 08:47 PM
  #66
camarokev400's Avatar
add another broken t5 to the list, my first gear finally broke totally at the end of last year, i now have a th350 in the car and it is sooo much better not quite as much fun but much more reliable.... anyone read about these gforce t5's everyone has been talking about ??? can you really make these trannys hold that much power.. i thought the whole problem was the case flexing?
Old May 21, 2003 | 10:38 PM
  #67
kfoley's Avatar
Car: '85 Z28
They're suposed to be able to hold 600 hp & 500 tq with drag radials and an upgraded clutch in a 3300 lb car. I think the case is probably the issue when you reach power levels higher than that. Until then it's probably the gears and mainshaft. I'm not a tranny expert or anything, but that would be my guess.
Old May 22, 2003 | 09:40 PM
  #68
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
here is some pic
Damn, that looks familiar...
Old May 22, 2003 | 09:42 PM
  #69
JAYDUBB's Avatar
Car: 1991 Camaro RS
Originally posted by camarokev400
Have any of you guys had this problem: when you are at a dead stop and start out in first gear it slams outta gear and will nearly rip your arm off. However if i hold the gear shifter foward with a lot of pressure it will stay in. And if i am already rolling and put it in first gear it will not pop out, and all other gears work perfectcly?
Either the synchro or the slider is shot. Could be the engagement teeth on first gear also.
Old May 24, 2003 | 07:21 PM
  #70
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
ive had two, first one had a bad bearing or somethin, now my 2nd one is starting to make weird noises to. both problems were in first gear
Old May 24, 2003 | 10:09 PM
  #71
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Mine's seen better days, but its still in one peice behind first an L69, then my L48 (350)
Old May 25, 2003 | 11:28 AM
  #72
Chris's 85z's Avatar
Car: 85 Z
Engine: 383
Never broke mine. Had it behind a stock 350 for 3 years till I spun a bearing built that into a 383 had it behind a 383 for 4 years and I was not nice to it! Still was holding up has 160,000 miles on it and I have had the car for 10 years now......Soo still holding up! Shifting great too! WOW Eh?
Broke the 3-4 fork in it about 5 years ago from power shifting it put one in from a S-10 still running great!
Old Jun 3, 2003 | 12:55 AM
  #73
Uncle Skeletor's Avatar
Car: 1991 Camaro RS
Engine: 350, Edelbrock Pro Flo efi
Axle/Gears: 4.10 on a torsen diff
Just broke my second T5 last firday. On the hunt for one once again....
Old Jun 3, 2003 | 01:19 AM
  #74
Car: 85 Z
Engine: 383
How did you break it? I'v heard so many people breaking them but I could not break mine.....
Old Jun 5, 2003 | 02:30 AM
  #75
Car: 1991 Camaro RS
I disintegated 3rd gear in both trannys by popping the clutch when I was shifting, the first one while upshifting and the second by downshifting.
Maybe I'm just pushing them too hard or buying craptacular transmissions or something. I don't think I have too much motor; I run 10.0s in the eighth.
Old Jun 5, 2003 | 10:34 AM
  #76
fb305svs's Avatar
ive been runnin mid 9's with mine, not a ounce of issues
Old Jun 5, 2003 | 05:57 PM
  #77
kfoley's Avatar
Car: '85 Z28
I think mine's about to let loose. I can't downshift to second at all unless I go to first then second and even then it whines and doesn't really want to go in. Besides it's been acting strange and making weird noises and vibrations lately.
Old Jun 6, 2003 | 03:27 PM
  #78
kfoley's Avatar
Car: '85 Z28
Well mine finally let loose yesterday night. I haven't abused it, but I haven't exactly driven it easy. Now I'm debating if I should buy a WC T5 to put in it temporarily then do the G-Force upgrade on it this winter, or get one straight from G-Force, or get a Tremec TKO. I'm building up a 450hp 500tq. 406 and putting it in in about a month, but I'll be driving it easy for the rest of the summer to break it in properly. What do you guys think? Put a WC T5 in now and hope that it doesn't blow up behind my 400 until I upgrade this winter, or get a Tremec and not worry about it? I'm kind of on a budget so going with the tremec will delay the motor. What do you guys think? Will the WC T5 last if I go easy on it?
Old Jun 8, 2003 | 09:22 PM
  #79
25thanniversZ's Avatar
I replaced the one in my 25th rs not the 25th Z cause they didnt put em behind tpi 350's, anyway I rebuilt the 25th rs's 13 times, only 2 of those wernt my fault...wife.....every gear evry sync at one time or another...not to mention the so called zero spin tollerance flywheel...turned it anyway....
Old Jun 28, 2003 | 11:18 AM
  #80
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Dude you're kidding me . Did you mean 1/4 or 1/8?
Old Jun 28, 2003 | 04:49 PM
  #81
kfoley's Avatar
Car: '85 Z28
Gotta be 1/8th, a T5 for sure wouldn't last running 9's in stock form.
Old Jun 28, 2003 | 08:44 PM
  #82
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
124k on my t-5....24k of it is behind my new 355. 4th gear has grinded since i have had the car.
Old Jun 28, 2003 | 09:02 PM
  #83
JesasaurusRex's Avatar
164k on my WC T-5, not even 1k on my new heads/cam/intake i drive it like i stole it. No problems so far, lets cross our fingers.
Old Jun 29, 2003 | 07:59 PM
  #84
Formula_355N2O's Avatar
you gotta learn how to drive it seems like to me, I mean, you wouldnt race a clapped out 305, so why would you not freshen the tranny and not drive it stupid? I mean, mine is behind a 500+ hp engine, and all I have ever done is burn up a clutch, you gotta understand that nothing is indestructible and you gotta drive accordingly.I still cut a 1.78 leaving at idle.... reving the crap out of it and dumping the clutch is never the fastest.
Old Jun 29, 2003 | 10:41 PM
  #85
But it does look the best and sound the best w00t
Old Jun 30, 2003 | 12:09 PM
  #86
Odyssey's Avatar
What a retard! (woot)
Old Jun 30, 2003 | 01:53 PM
  #87
you are such an idiot! its not cool when you burn your clutch, its not cool when you blow the tires off your car, unless you are sixteen of course. I guess when you cant go fast, all you can do is burn rubber!
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
