Rearend Swap
Old Nov 29, 2002 | 05:01 PM
RacersNME13's Avatar
Rearend Swap
I have an 89 Firebird Formula with four wheel disk brakes. Will a rearend out of an 87 trans am with four wheel disk brakes fit in my car? Are the rearends the same?
Ok thankyou, quick question though, can i take the callipers off my 89 rearend and use them on the 87. Will they fit?
Old Nov 29, 2002 | 06:30 PM
4L60bliss's Avatar
It will fit, however, I beleive the brake calipers are different. I think in '89, they had Aluminum PBR Calipers, and I know for a fact that in '87 they had the notoriusly sh1tty cast iron calipers. Therefore you may run into problems with the e-brake cables and brake hoses but I don't know for sure.
Old Nov 30, 2002 | 08:36 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right, and you may also have the 28-spline axles in your 89 rear, if it's a 10-bolt.
All in all, it would be a major downgrade to your car. I would not do it if it were mine.
If you go from the aluminum calipers to the older crappy cast-iron system, you will need to change your master cylinder and proportioning valve, and modify the prop valve; otherwise they rear brakes will work basically not at all instead of merely very weakly and unreliably.
Old Nov 30, 2002 | 08:38 AM
Z28DJP1987's Avatar
Why go backwards with that rear, unless your mind is set on the gears??
The 89 9-bolt with the PBR brakes is a better set up in my opinion.
Maybe because thats what I am using.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
