can i still use this 9-bolt?
Old Dec 7, 2002 | 08:35 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
got a b/w 9 bolt for $50 (probably saw it in the ads if you where there). Took the cover off to inspect it and it has a cone clutch posi unit that is still nice and tight, surprisingly, and everything seems to be in order. There is one small problem i found. On one of the teeth on the ring gear, there is a very small amount of surface pitting. overall, the area on the outer part of the tooth is probably less than a mm in legnth and probably 1/3 mm in width with several very small shallow pits. Looks like there may have been a defect in the material that predesposed the area to surface fatigue failure. All of the other teeth look like theyre in good shape. Do you guys think i could get another 10k out of this thing w/o any problems? I know i wont be able to easily find another gearset for this thing so im probably stuck with what it has.
Old Dec 7, 2002 | 08:45 PM
Eightyninef's Avatar
I would use it. The worst that would happen is it would be noisey. but I wouldn't worry too much.
Old Dec 7, 2002 | 08:49 PM
Car: 88 Camaro SC
Engine: SFI'd 350
thats what i figured, also. the rear will probably start complaining before its in any danger of failing. hopefully itll hold out for a while.
Old Dec 8, 2002 | 11:45 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Should be ok. Run it until it breaks. Gears are available here www.9bolt.com
Miles
Diff Solutions
www.9bolt.com
ZMWojnar
Brakes
May 12, 2019 10:43 PM
6speedIROC
Sep 13, 2015 01:29 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
F-Messenger
Carburetors
Nov 14, 2001 04:28 PM
