shift point?
Old Dec 15, 2002 | 07:54 PM
Cyclops's Avatar
shift point?
Ok i just got another camaro Its a 88 iroc l98 w/ 700r4. my other camaro is now a t56 and I don't know much about autos. My question is at what rpm is a stock 700r4 sposed to shift at?
At wot my car will not shift untill I let off.(around 5700rpm)If I stay in it I dont think it will shift. I just changed the filter and fluid. One more question is there a way to drain all of the fluid to change it? thanx
Old Dec 16, 2002 | 08:52 AM
Charyou Tree's Avatar
To change the fluid, you gotta pull the Transmission Fluid pan. You'll need a new gasket on hand as well.
Old Dec 17, 2002 | 01:13 AM
Cyclops's Avatar
Yeah I changed it once, but I want to know if there is a way to drain the conveter too?
Old Dec 18, 2002 | 11:23 PM
Pro Built Automatics's Avatar
The capacity on the 3-4 clutch pack is just about gone with the transmission as is to handle WOT shifts. If you do not want to spend the money on a new transmission at this time, and assuming the fluid and the "3-4 clutches and 2-4 band" are in good shape, you could install the Trans-Go Performance Shift kit, Corvette servo, and the larger boost vales to solve this problem. Worst case scenario, you use these parts in the next rebuild.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Out-Cast
Sep 11, 2015 08:03 AM
