Speedo corrections
Old Dec 17, 2002 | 09:59 PM
Berlinetta's Avatar
Speedo corrections
Okay, im fixing to do an auto to t-5 swap while putting in 3.73 gears and i had a question. My car is a 91 RS and has the blasted electronic speedometer. Correct me if im wrong here but doesn't the electronic speedo get its signal from the VSS? If this is the case, what do i have to do to correct my speedometer for the gear swap? Isn't the VSS sensor essentially the gear being driven by the drive gear inside the tranny? I know in an older car, you have to change the drive/driven gears to correct for new gears. Does that mean that I have to change both the drive gear inside the tranny and change the VSS sensor? Thanks for helping to answer the questions a very confused board member.
Old Dec 18, 2002 | 12:52 AM
sober333's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I am also changing the gears in my 91 rs to 3.73 and i think that all you have to do is buy the speedo correction gears from slponline.com they should do the job.
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
topteam54
Oct 6, 2015 12:21 AM
TrevinE
Sep 14, 2015 03:20 PM
