installing new gears...
Old Dec 18, 2002 | 11:30 AM
3504mula's Avatar
Car: 90 Formula
I just bought new Eliminator 3.42's (since a few of my teeth are broken off my ring gear) and I was wondering what you guys recommend about the installation kit. I know there are kits in Summitt and Jegs but I have heard for quietness you should use genuine GM bearings. I called my dealer and he said they don't sell a complete kit, just everything seperately. I want the quietest rear end possible (mine has an extreme whine right now) so if I have to order everything seperately I will.
But would it be easier to order a Ratech kit or whatever and then order the important bearings from GM???
Should I just use all of the bearings out of the kit and forget about GM???
Have you guys had any success with kits like this???
Any help is appreciated.
Old Dec 18, 2002 | 12:53 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That is a bunch of hooey. GM bearings are no different from anyone else's. Just get the Ratech kit and be done with it. I've used a certain number of them, they work just fine.
I'd be more concerned about noise from the gears.... who actually made them?
Old Dec 18, 2002 | 03:19 PM
3504mula's Avatar
Car: 90 Formula
The gears in there now are GM but like I said the ring rear has 3 teeth broken off so maybe the pinion depth wasn't set correctly or something.
I bought the rear end used and I think the guy before me had aftermarket gears in it and then put the old gears back in it for some reason.
Thanks for the input. I really appreciate it. I will try the Ratech kit out.
Old Dec 19, 2002 | 06:19 AM
ede's Avatar
ede
there's a real good chance the "real gm bearings" aren't made by gm. more likely timkin, if it were me i'd not put anything in it but timkin bearings.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
