Ford toploader
Old Dec 19, 2002 | 02:36 AM
jeff85iroc's Avatar
Ford toploader
Does anyone have a toploader in there car or intends on putting one in.
Any info would be apreciated as i have one sitting in the garage that i want to put in.
Thanks.
Jeff
Old Dec 20, 2002 | 12:15 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I have no idea how you would mount a TL Ford, which is designed to be used on a BBF, to a SBC. Personally, even if i could get it to fit, i wouldn't use one. They were good trannies back in thier day, but they dont compare to whats come out in the last 20 years.
Old Dec 20, 2002 | 01:50 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
They were POS's back in the day too. The top loader is useless in a car, you would have to cut the floor out to even use it and since its a fnord all kinds of custon crap would need to be installed. If you reeeaaallly want a stick (on the cheap) nab a saginaw 3 speed standard there easy to find and would be alot easyer to install.Besides with a toploader you wouldent use 1st gear anyways, the second you let off the clutch in 1st its time to shift not even good for a little burnout.
Old Dec 21, 2002 | 01:32 AM
jeff85iroc's Avatar
Thanks for the reply,s.
I really don't want to have to cut the floor so i guess i will sell the loader and look for something else.
Thanks again.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
mcbitchman
Sep 30, 2015 01:00 PM
mcbitchman
Sep 29, 2015 12:32 AM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
