Just installed the Pro 5.0, WOW
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Thunder racing had it on sale for $159 so I decided to buy it. I am glad that i did. The shifts are a lot shorter and really crisp. You can hit fifth gear just as fast as you can hit 3rd. Installation was striaght forward however installation is much more involved for camaro owners. If you have a bird you just have to take the center console off but for camaro guys you have to remove the lower part of the dash (under the steering wheel), remove stereo and climate controls, and the center console. Other than that it was pretty easy. Check out some before and afters. I put the old shift **** on because my Momo sits to high. I have to get it machined out again so that i can get it to sit lower. I took mutiple pictures and may write a tech article on this.
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
Man, you removed a lot more than you *had* too. I remove [on my camaro] the top console cover, the AC/radio plate, shift plate, and just loosen the console itself to get at the screws to the weather boot. The AC and radio stuff you just ease out of the way.
The Pro 5.0 is a great shifter. Haven't met anyone say anything bad about it. Some others prefer the other brands but you just can't go wrong with a Pro 5.0.
looks good.
looks good.
Car: '90 RS
Engine: 377 LSX
Well I thought I could just manuver around the console as well, however, I could not get at the bolts that surrounded the rubber cover thing over the floor pan. It was hard keeping it out of the way so I just decided to remove it and get it out of the way so I could do a good job. I only had simple tools to because all of my tools were stolen last week, that is a whole other story
Car: '90 RS
Engine: 377 LSX
dunerida82
That is a pic of the stock shifter vs the Pro 5.0. The stock shifter is an absolute piece. My car only has 34,000 miles on it and all of the rubber surrounding that stock shifter was torn and ripped and worn to all hell. As for the difference the Pro 5.0 is a little shorter (about 3/4") in actuall hieght but the throws are %17 shorter and more presice. You can actually hit fifth as fast as you can hit third. I could never do that with the stock shifter. You can feel each gear go into place and you can feel each gate as you go throught the gears. I belive if you want a shorter handle for this shifter you can get Lou's Short Stick which is like $50. It is made for the Pro 5.0 for 6 spd's but it says it can be used on fourth gen 5spd's which uses the same Pro 5.0 shifter as thridgen T-5's. I may get that because I want to use my Momo **** that is in my firt pic at the top of the page. I had that think thread matched to the shaft but it doesn't screw down that far and sits to tall and feels akward.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
I might try the lou's later on mine, but with my T56 and Pro 5.0, just ended up cutting about an inch off the stick, since its got like 2" of thread, and the mba **** i have is supposed to lower it a bit too.
Originally posted by MIG-29
nice job mister godfather
it looks awesome, and so does your sound system.
tell me, what do ya think 'bout mine?
Fernando.
Fernando.
Oh my. Not my cup of tea, but interesting nonetheless.
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
yeah!!! my friends all say i'm nuts, but i like it, i did show it to a cop, he couldnt believe it, but he did like it too.
actually (just for the records) i'm a private pilot, but i earn my living as an aircraft mechanic, so you guys wouldnt believe how much aviation stuff i got on my babe, and it works!
anyway i think the shifter on our friends car is awesome.
happy new year to all.
Fernando
Fernando
Iroc8t8
May 4, 2026 08:09 PM
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Aug 20, 2015 09:36 PM
