Why not use the '93 Lt1 T56 trans?
Old Dec 21, 2002 | 01:43 PM
Scott C's Avatar
I am seriously considering a swap from my auto trans to a T56. I've been doing research and I know that the '93 is not preferred due to the .62 overdrive vs. the .50 in a '94-'97 T56 (the .62 is still better than the overdrive in my 700R4). I also like the lower first gear ratio in the '93. Other than the gear ratios, why not use the '93 T56?
The reason I ask is because a brand new '93 Tremec T56 (10236021) goes for ~$1700 where a new '94-'97 Tremec T56 (12558016) goes for ~$2900.
What makes the '94-'97 T56 worth $1200 more? Experts, please!
Old Dec 21, 2002 | 04:31 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
You already posted the difference, its in the gearing, and i believe the gearing was the main factor in the 94-97 one having a higher torque capacity.
Old Dec 21, 2002 | 11:48 PM
TBI305Camaro's Avatar
Im kicking myself in the *** right now. I just found a 95 lt1 T56 for 2500$ with 80k...damage to the front end. OMG I wish I would have bought that instead of my new motor...not only would I have a nice motor but id have a t56, better rear, and all the 4th gen interior i could handle!!!
Old Dec 22, 2002 | 09:38 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Also I believe the 94+ is rated to handle 50 more ft.#'s of torque
Old Dec 22, 2002 | 03:27 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
You are correct. It follows the gearing differences...
93: 400 ft-lbs.
94+: 450 ft-lbs.
Old Dec 23, 2002 | 06:09 PM
Marc 85Z28's Avatar
93: 400 ft-lbs.
94+: 450 ft-lbs.
That's what they're rated at. They have been known to easily handle twice that.
Old Dec 23, 2002 | 06:19 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
IIRC, the '93 T56 also had a 2.95 1st gear. I know for a fact the '94-'97 T56s had a 2.66 first gear. This is what dictated the torque rating (from my understanding).
Old Dec 25, 2002 | 02:59 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
To me its if it can handle a LT1 and then some. Then it can handle a 3rd gen motor O_o I got the 94+ one though cause thats the one that I found for a good price.
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
