4L60E help needed!
Old Dec 29, 2002 | 12:42 PM
nicksL98's Avatar
4L60E help needed!
4L60bliss/probuilt/vader and the likes, i am working with a 98 Trans am with 83K miles. under normal acceleration the car runs up to 4500 rpm in first gear, and will not shift into second unless you let off the throttle a little. from second gear through o/d it shifts as normal and kicks down fine on the hiway, etc. just a problem with first gear. is it a bad upshift solenoid ? im not too familiar with these. Thanks in advance!
Old Dec 29, 2002 | 01:41 PM
4L60bliss's Avatar
Are you sure its going into 4th? Did you check to see if it has Reverse as well? Sounds like something might be wrong w/ the band.
Old Dec 29, 2002 | 01:49 PM
nicksL98's Avatar
ill have to confirm 4th gear. my scantool only has cards up to 95 so it doesnt work with this thing. it works in reverse but i didnt try to load it to see if it has a delay to engage reverse. I'll see if i can get out there tonight and check it out. i will keep you informed!
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
