Rear end noises, is it the end play?
Old Jan 4, 2003 | 01:47 PM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
Okay, heres my problem. I did the fourthgen rear swap, and now the thing makes this godawfull dry scraping sound. It sounds like its comming from the discs. I checked them and everything is in there right and there is no rubbing. The axels seem like they have alot of play in them. Is this normal for a rear end? I swaped from drums so I couldnt pull on the axels like I can on the disc rear. I put in the new prop valve and everything,so I do not think it is a brake issue, becasue the noise continues when I aply the brakes. I checked the gears before I put it in no chipped teeth or metal flakes in the fluid. What i think is happeningis the axles are moving out ward when I start to drive casueing the rotors to rub the pads. Someone please help.
Old Jan 4, 2003 | 01:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The axles normally have some end play, usually anywhere from 1/16" to 1/8".
Look at the inside of your wheels very carefully. I'd bet they're dragging on some part of the brakes.
hectre13
Dec 11, 2023 08:14 AM
pimp2303
Jul 27, 2017 02:03 PM
B_Dubya
Aug 26, 2015 05:09 PM
86White_T/A305
Aug 17, 2015 12:16 AM
BlackBoulder
Aug 11, 2015 11:15 PM
