Bad vibrations after trans swap.
Old Jan 4, 2003 | 09:20 PM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Ever since I put the Tremec in my car I get a had a really loud and strong vibration coming from my shifter. This happened at around 3500rpm. Mostly I notice this vibration when I'm in 5th, going about/between 65-75mph. It happens when I let off the gas, still in gear and also even worse in neutral. When giving part throtle the vibration goes away. The vibration stops at higher speeds.
Most opinions I got were pointing to the drive shaft. I replaced mine w/an aluminum one out of an LS1 car and the vibration became much quieter and considerably less noticable but it's still there. I know the driveshaft definetely had something to do w/it. I'm thinking to have this new shaft balanced proffessionally but other then that I'm clueless. Any help would be most appreciated.
Mike
Old Jan 5, 2003 | 11:54 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Mine has a similar problem.
Noise and vibration at about 70.
Picking up an aluminum driveshaft on Monday, since most have told me this will help.
Mine was there before the new trans, but is more noticeable since putting in the Tremec.
-Rich-
Old Jan 5, 2003 | 01:52 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Yeah. The driveshaft helped a lot. I would say about 75% of the vibes are gone but w/the T5 it was really smooth and I'd like it back that way.
Anyone else w/the same kind of problem?
Old Jan 6, 2003 | 10:19 PM
BORLAZ06's Avatar
I have the sme problem after my tranny swap. I reallt think its my new driveshaft. Imma get it rechecked on wednesday and i'll let you guys know whats up. If that doesnt help my last resort if gettin my pinion angle checked once again. If it aint neither then imma shoot myself. Damn money pit
Old Jan 6, 2003 | 10:35 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
That's the thing, my new driveshaft helped. A lot!. But the vibe is still there, less than before but still there. I'm using process of elimination here, sort off. I know the driveshaft had a lot to do w/it. I'm gonna go to a place that specializes in driveshafts and U-joints. I've found out that there seems to be only one shop in NY(five boroughs) that actually ballances driveshafts. They also make/cut custom driveshafts. If anyone can solve my problem it's gonna be them. I think. If not then I guess I'm gonna have to live w/it.
Old Feb 3, 2003 | 06:24 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
i think all DSs need rebalance after changing to the tremec yoke
The LS1 yoke had a large ring on the outer perimeter. Im thinking that the elmination of that changes the balance significantly...
i got one hell of a vib that did not exist b4 the tremec.
My tremec was used.. and the yoke showed signs of slight wear. Im thinkin the imbalance is beating the rear bushing out of the transmission.
Old Feb 3, 2003 | 11:40 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
flywheel maybe/
Old Feb 4, 2003 | 06:52 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
i used the same flywheel and clutch..
they were not removed and were balanced with the motor b4 it went it (and were fine with the T5).
The other point is,, the vibration gets worse at higher speeds (4thgear) not higher rpm.
Old Feb 4, 2003 | 11:53 AM
85yellowiroc-z's Avatar
check the output shaft for excessive play.also,did any bearing caps fall off your u-joint during the swap?I would have replaced them(u-joints) while it was out anyways...check for play there also.hope i helped
Gary
Old Feb 4, 2003 | 02:25 PM
SpeedJunkie's Avatar
Car: 88 IROC
Is this the same vibration even if you have the clutch pushed in? Maybe its the pilot bearing? just a thought
Old Feb 4, 2003 | 04:47 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
no vib in netrual or clutch in..
new u joint.. had to be to go from the C4 yoke to the LS1 DS.
I think Im going to have to pull the DS and check for balance first.. then if thats ok.. im probably going to put a new rearbushing/seal in...
db057
Aug 22, 2015 08:17 PM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
3rdgenparts
Aug 6, 2015 09:03 AM
