Does "posi"= "limited slip"
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Dumb question I'm sure. I always thought they both were the same thing, i.e power to both wheels.
I found a 3.42 rear end at a salvage yard still tied on to the camaro its from. The cover is gone but all internal components are in view. Drive shaft gone. I know there is an easy way to tell if its posi/ ltd slip, but I can't remember. Could someone please refresh my memory?
thanks...will have to go back and check it out cause I don't remember.
I'm not sure if I want a 3.42 rear anyway. It would be alot of fun, but there does not seem to be much RPM room with the TH700R4. I am worried about highway driving. Presently with my 2.73's, I run @ 2200 RPM at 60 MPH.
Is this something to be concerned about??
Car: Camaro
Engine: Carbed L98
Transmission: TH350
3.42 is a all around good gear for the 700R4. I dont think you could go wrong, as long as the Rear end you get is good.
cool....I found one on a salvage car...I'll just pull it and pay $25 for it and keep it around until i decide
Car: 1991 Formula
Engine: 350 firebreathing inches of Small Block Chevrolet
Transmission: A 700R4 that has trouble handling the formentioned 350.
Not really sure of what you are asking in the original post. I think you want to know if a posi is the same as a limited slip. The answer No but still Yes. In the 80's the term used was posi but they where truely limited slip. Confused?
A posi is a rearend that turns both wheel the same rate all the time. A limited slip is just that, it will only spin one tire up to a point and then the other will catch (i.e. limiting your slip!!). I don't think GM has used a true posi in a car since the early 70's.
. And of course an open rear end just spins one tire all the time.
Hope this answers your question. Later, Garrett
. And of course an open rear end just spins one tire all the time.Hope this answers your question. Later, Garrett
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, you're thinking of a locker or a spool. Posi rears are limited slip. "Positraction" was GM's trademark for their limited-slip rear ends. Ford had their own name for it, and so did Mopar, but the GM name is the one that stuck.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
and if the other one spins in the same direction, then its posi. If it spins in the opposite direction, then it is open rear end.
