T-5 - Where to get?
Old Jan 9, 2003 | 10:28 PM
CETATornado's Avatar
T-5 - Where to get?
I've decided that I'm probably going to look for an L98 Camaro and do a manual tranny swap rather than take the 305 and already have the manual.
I did look up the Tech Article, so I'm all set on how to do the swap itself - however, the only problem is finding the T-5. I don't really want to buy the T-56, as I don't feel like spending that much money on just a new tranny. Where can I buy the T-5 transmission from?
Old Jan 10, 2003 | 10:26 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Borg & Warner T-5s that came with most 305's aren't strong enough to hold up to a 350. That's why GM never optioned them on a 350.
You could go aftermarket and get a Tremec T-5, but you will spend some $$$ to get one. You might be better and cheaper off by getting a T-56
Old Jan 10, 2003 | 04:45 PM
Hmm, I had a bad feeling something like this would be the explanation...
I suppose I will have to go with either the Tremec or the T-56. Thanks for the info.
Old Jan 10, 2003 | 05:29 PM
BRIrocZ's Avatar
Car: 97 Z28
Transmission: A4
There are a few people running deep 13's and even 12's on stock WC t-5s. They can hold up if your gentle and an aftermarket shifter with shift stops is a must.
Old Jan 11, 2003 | 12:57 PM
I'll probably still get an aftermarket tranny though, just to be safe...and with the amount of mods I'm eventually planning, the stock T5 may have some trouble holding up .
I noticed that the Tremec TR-3550 is rated at 425lb/ft torque capacity, which is certainly more than enough...
Where's the least expensive place to get a TR-3550? How much can I expect to pay for a good-quality bellhousing and shifter?
Old Jan 11, 2003 | 10:43 PM
CrashedMatrix's Avatar
I have a v 8 t-5 out of my 91 bird that i just took out and it works perfect car had always been babied. let me know if you are intrested!
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
