Tremic TKO ....direct bolt in ?
Old Jan 13, 2003 | 07:53 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I was just wondering if anyone had experience with these tranny's .....My t-5 is Pooched and I need a Better one
What do I need for this swap
Old Jan 13, 2003 | 08:17 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
im sure others will chime in.
Requires:
adapter plate (eliminates 15degree trans rotation) and bolts a Ford trans bolt pattern up to the GM bellhousing.
C6 yoke for driveshaft.
Spacers on the crossmember to account for slightly lower transmount.
Speedo converter
Old Jan 13, 2003 | 11:11 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Installed my TKO 2 weeks ago.
Got the kit from Fortes.
http://www.fortesparts.com/tremec/tr3550.html
Kit comes with:
Tremec TKO trans
w/longer input shaft and input bearing retainer (to make up for the adapter thickness)
Bellhousing adapter
Crossmember spacers and bolts
Speedometer adapter (electronic adapter, choice of gear ratio)
Shifter adapter plate (allows you to re-use existing stick)
C6 Driveshaft Yoke
Spicer U-joint (adapts C6 yoke to stock driveshaft)
Backup Light switch
3 quarts of GM Syncromesh Fluid
You'll need to buy a few miscellaneous bolts as the Tremec's SAE and the T5 is metric.
You can use the same throwout bearing and clutch.
Trans Mount and Torque arm bolt right up.
You'll need to modify the crossmember a little to get everything lined up.
Swap took me and a friend about 6-1/2 hours including two trips to the hardware store and lunch, but we were able to use a lift at the dealership.
If you're doing it in the driveway, allow yourself a whole day or even a weekend if you drink a lot of beer while you work.
-Rich-
Old Jan 14, 2003 | 04:28 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
OMG :hail: :hail:
Thanx alot for the info ........hay just curious .....what did he charge you???
Y a.... I will be doing this in the garage ....... So from this point on when I am shopping for a clutch or a flywheel or anything like that .....I can saftely say that it is for a regular T-5 ( all the consumable parts I e ... throw out bearing , clutch , etc )
Also I talked with Mike Fortes on the phone he said that they sell a crossmember as well ....... didn't want that ? I am going to get it
Old Jan 14, 2003 | 06:44 PM
Car: 92 Camaro RS
It was $2192 (plus shipping).
He didn't mention the crossmember to me, but I may get the Spohn Crossmember/Torque Arm this summer.
Anything for the T5 should work if you're using the stock bellhousing, A Lakewood bellhousing complicates things a little.
I'm using the Hayes 30 Lb. Billet Flywheel (#10-530), Centerforce Dual Friction Clutch Disc and Pressure Plate (#DF1611056) and Centerforce Throwout Bearing (#N1716).
Also Moroso Roller Pilot Bearing (#41100).
-Rich-
Old Jan 14, 2003 | 08:16 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Thanx man !! I want a centerforce as well
Actually I got my wires crossed ..... it was the t-56 upgrade from tremic .....THEY sell the new x member
oppsssssss
anyhow ...thanx for the part # .....hehehehehe they WILL come in handy
:rockon: :rockon: :rockon:
Old Jan 14, 2003 | 08:52 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Axle/Gears: BW 9 Bolt/3.70
Teaser...
Swapped out a 700R4 for a TKO this weekend. I was one u-joint away from a test drive. It goes in tonight!
TKO, Lakewood scattershield, pro5 shifter.
-Schultzy
Old Jan 15, 2003 | 01:21 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
[i]
-Rich- [/B]
Any pics of this " modificatin " ...... or is it just adding spacers. I would hate to get it in and find out I need some special cutting device for the thing to work
Thanx again
BTW Schultzy ......... thanx for the tease LOL
Old Jan 15, 2003 | 01:57 PM
Car: 92 Camaro RS
Need to elongate a couple holes and drill a new one.
Crossmember actually sits farther rearward on one side afterwards. And yes it's spaced down 3/4".
Nothing major.
No welding required (if that's what you're worried about)
If you have an electronic speedometer, you'll need to trim one of the mounting bosses off of the trans to clear it.
The trans mount pad has four bolt holes (the two outside ones for Ford applications-two inside fit gm mounts)
Just need to cut it off on the driver's side, just inside of the outer bolt hole.
It's aluminum, you could use a hacksaw if you had to (I used a die grinder and cutoff wheel-quick)
If you don't have an electronic speedo, you won't need to do this.
-Rich-
Old Jan 15, 2003 | 04:20 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
wooohoooo ... thanx again man !!!!
that doesn't sound toooo intimidateing . I have a mechanical speedo ( another reason I didn't go for the T-56 swap ...moree $$$$ ) But the rest of that spounds pretty easy
:hail:
Old Jan 15, 2003 | 04:29 PM
Car: 1989 GTA
Good luck with your project man. I finished up last night about midnight with mine. Nice! The little L98 feels real good with the five speed.
BTW, I used the Spohn crossmember on my car but I have the crossmember and spacers that Fortes sells if you are interested. If so just PM me and we'll talk.
-Schultzy
Old Jan 15, 2003 | 05:03 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
cewl ....PM away !!!!!!!!!!!
Old Jan 18, 2003 | 08:54 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
i seem to be missing the trans to adapter bolts.. anybody know the size??
Also.. I have two bolts that have the first .5" unthreaded but they are too short to be the adapter bolts. They have an aluminum retainer with a 90 degree bend in them.. anybody know what these do?
thanks
Old Jan 19, 2003 | 01:21 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
the trans to adapter bolts should be like 1/2 " allen head bolts i believe....they are pretty beefy.
Old Feb 18, 2003 | 09:24 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Just out of curiousity...did you need to shorten your driveshaft at all?
I have a 1LE driveshaft and it is the same between auto and manual...but since I am converting from auto to manual trans at the same time as the swap...just want to make sure I don't need to modify the driveshaft at all...
Thanks...
Old Feb 18, 2003 | 09:56 AM
Car: '91 Camaro RS
you'll need a different transmission yoke, but the overall length is the same....the output shaft is just different. the kit should come with the yoke and an adapter u-joint
Old Feb 18, 2003 | 10:12 AM
Engine: LS3
Transmission: 6L80E
I will have to check that...I bought a used (but hopefully complete) TKO setup from a friend of mine...he bought it over a year ago and never installed it...
I was hoping that the answer was in the yoke, cause I really don't want to find a different driveshaft
I will check to see what I have and go from there...
Thanks!
Old Feb 18, 2003 | 10:23 AM
Car: '91 Camaro RS
Thanks!
no problem, if you find that you dont have one just call fortes and have him send you the yoke and the u-joint that goes with it.
Old Apr 18, 2005 | 02:26 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
Spicer Conversion U-Joint
Hey TKO swappers...
I'm working on my TKO install and I wonder if anyone can tell me what the part number is on this Spicer (or any other make) converion U-Joint is??
Hoping someone hasn't thrown the box away yet!
Edit: Seeing as this is a fairly old thread, I started a new one at:
https://www.thirdgen.org/techbb2/sho...hreadid=292012
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
