adjusting stops on B&M Ripper
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey guys i have had my ripper shifter in for a while now and when i get on it, like 5g and above ever since i got the shifter it will grind be4 it goes into gear, like there no hesitation to go in it just seems to grind on it way in there, i dunno if i am over throwing the shifter or wut, buthow do i even adjust these stops. i bought the thing used in almost brandnew shape and wiht no instructions so any help is appriciated. alsodo u think this coudl be a cluthc prob maybe? its a brand new clutch but u never know. well thanks guys
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
SOunds like Synchro's to meeeeeeeeeee
I JUST had the EXACT same thing happen to me before I put it away this winter. Trust me DO NOT DRIVE IT LIKE THIS ....cause now ........ I have to buy a tremic TKO
And your 89 has the same tranny as my 89 iroc 5.0L its a Borge& Warner T-5 World class ( piece of chit slushbox ) ....... why do you think its not in a 5.7L car ? Anyhow get it rebuilt fast .......and don't cheap out on the rebuild ........they are weak enough with what they got stock .
good luck to ya
good luck to ya
Car: 89 Formula
Engine: Carbed 5.7
yea i know all about how weak these peices of junk are. well its only got 1400 miles on it with the 350 and 86 behind a stock 305 tbi so i thougth it woudl be ok for a while. anyways i just made this thing a little to extreme. i can;t afford 2 grand for a tremec or 1500 for a t-56. and the gas milage is also to horrible on this thing to drive it everyday so i am just gonna sell it and get somthing practical that can still have fun with. man i wish chevy knew how to build a car in the 80's, woudl have been nice
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
On my Hurst billet plus they say to back the stop bolts out, put the car into gear, bring the bolt up to touch the stick, then back off 1/2 turn and lock in place.
I agree you have syncro problems. Get it fixed now before you do any more damage. Gears get EXPENSIVE!!!!
And, you CAN rebuild a T5 yourself. It's not hard at all.
Car: 1989 IROC-Z
ya ......I just don't like crawling under a car to rip out a tranny
I'll fix it once and be done with it . Hopefully the TKO does it for me
dimented24x7
Sep 6, 2015 03:51 PM
