700r4 only 1st and reverse
Old Jan 19, 2003 | 10:39 PM
brokenwheels's Avatar
I have an 86 Trans Am. I was driving it the other day and it shift into second gear (or so I thought) very hard. Then all i had was first gear. The tranny had been shifting harshly for about a week. Anyone know what damage I have done?
Old Jan 20, 2003 | 12:02 PM
Ken73's Avatar
Car: 82 Corvette
Engine: 350 CrossFire
When was the last time you changed the fluid? It's possible you can fix it (although unlikely) by pulling the pan and valvebody, and cleaning the valvebody thouroughly.
Worst case scenario, you can pull it and rebuild it better like I did.
Old Jan 20, 2003 | 04:59 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Were the shift points normal, just unusually hard, or were they later than usual? Was it just the 1-2 that was hard or all of them? Have you tried adjusting the TV Cable?
Old Jan 20, 2003 | 06:15 PM
irocbsa's Avatar
Dang B., you have Message Board Multiple Personality Disorder all over the place don't you. :sillylol:
Old Jan 21, 2003 | 09:46 AM
Nordbert's Avatar
irocsba- Now that's funny!
I just wish I knew how many boards!
Old Jan 21, 2003 | 11:54 AM
I should have told you. The tv cable caused the problem. The shifts were at way higher rpm and i neglected to check it out. I obviously did serious damage to the tranny.
Old Jan 21, 2003 | 05:15 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Look here, 'tard, I was "GMTech" back before this board was "the old board", but the "old-old board" Didn't I already explain this to you
Old Jan 21, 2003 | 08:37 PM
irocbsa's Avatar
Yeah, you told me. I just don't listen cause you never have anything worthwhile to say.
Old Jan 21, 2003 | 09:00 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Just remember who's tranny is on my bench...
Old Jan 22, 2003 | 04:31 PM
irocbsa's Avatar
"This is by no means an endorsement to fill my tranny full of cat pee". And what are you doing messing around on the boards, get out that and work boy.
Old Jan 24, 2003 | 06:26 PM
ssbowtie1's Avatar
Its your governor man, take out the governor cover and feel inside if there's more than one piece then time for a new one
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
