Check out this TKO conversion on eBay!
Old Jan 24, 2003 | 01:13 PM
Scott C's Avatar
http://cgi.ebay.com/ebaymotors/ws/e...3&category=6780
I've e-mailed this guy and his quick response was, "Hello, The trans is new, it comes with a speedo adapter, reverse switch, bolts and converted to fit your bell. You will need to shorten your driveshaft. Thanks
Eric Swarr"
Tremec TKO is $1795
Temec 3550 is $1595
I've seen these lower priced conversions at other sites like www.darkhorseperformance.com. They all require that you shorten the driveshaft, but they will bolt right up to the T5 bell housing. How do these conversions differ from Mike Forte's conversion www.fortesparts.com?
If you don't want to shorten your driveshaft, then Mike Forte's kit seems like it's the way to go, but it's a couple hundred bucks more. What is the downside of shortening my aluminum driveshaft? Please help
Old Jan 24, 2003 | 01:26 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Leaving aside the aluminim DS issue. Will one from a 200C fit - I think it's shorter than the DS from a 700R4.
Old Jan 25, 2003 | 03:15 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The ones from a 200C, 200-4R, or a four-speed manual are longer: the trannies themselves are shorter.
Pete
Old Jan 25, 2003 | 03:58 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Right - I had it backwards - I been looking at too many variations for the tranny swap on my own car and I still can't decide.
Old Jan 25, 2003 | 10:11 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
i cant see how you would have to shorten the DS
if it does not have the adapter. That adds about 1".
I don't think they make 3550s with longer tailhousings.
deracer
Apr 11, 2016 12:04 AM
evilstuie
Feb 28, 2016 03:33 PM
J.C. Denton
Aug 31, 2015 03:11 AM
jharrison5
Aug 19, 2015 05:53 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
