T5 driveshaft bushing - how to replace?
Old Jan 25, 2003 | 10:53 PM
David Trimble's Avatar
Ok- now that I've got a new bushing... how do I get the old one out and the new one in without trashing it? Or do I need the puller and tool that the service manual mentions?
Thanks....
Old Jan 26, 2003 | 05:40 AM
ede's Avatar
ede
puller would be the way to go. you could use a punch or small chisle and push the side of the shell inward and colaspe it and work it out that way.
Old Jan 26, 2003 | 09:58 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Just go to Auto Zone and "rent" the tool. It beats destroying your extension housing, and makes it only take about 30 seconds to swap it.
Old Jan 26, 2003 | 04:18 PM
Autozone's got them for rent? Thanks- I'll check it out!
Old Jan 27, 2003 | 08:31 AM
Steve89GTA's Avatar
Hold on a sec,
Are you guys talking about the bushing in the tail end of t5 tranny's that the driveshaft rides on? I need to change mine. I'm pretty sure my whinning noise is coming from there and there are small groove marks on my yoke.
Are you guys saying i can get to it without removing the transmission with some sort of puller???
Thanks for the help...
Old Jan 27, 2003 | 04:24 PM
Steve- that's the bushing. I've got my tranny out of the car and apart for a rebuild so it's no big deal for me to just pound it out if I have the right tool, but I would think a puller would be available if it's still in the car.....
Old Jan 27, 2003 | 04:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There are pullers available, but I don't think Auto Zone has them.
If the trans is apart, you use a bushing knocker type of tool. Just like for cam bearings, auto trans work, etc. Very common tool. I use my actual cam bearing tool.
Old Jan 28, 2003 | 11:54 AM
Steve89GTA's Avatar
Thanks for the responses guys. I had my WC T5 apart a good 4 years ago so I don't really recall too much.
Here's what I need to know.
Will a tranny shop like AAMCO or similar have the puller required to simply remove the driveshaft and pull the bearing out form the rear of the trans?
If so - that sure as hell beats me dropping the tranny and splitting the case to get at it from the inside.
Thanks for the help !
Orr89RocZ
Apr 25, 2016 08:28 AM
TheExaminer
Aug 25, 2015 07:34 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
NBrehm
Aug 5, 2015 07:57 PM
