?'s about putting a th400 in my z
Old Jan 27, 2003 | 06:35 PM
1badblue87z's Avatar
I have a th350 in my car right now and came across a 400 that is in much better condition, I was wondering if anyone else has the 400 in their car and if they ran into any problems with the swap.
Old Jan 28, 2003 | 02:18 AM
EvilCartman's Avatar
Car: '82 Z28
Got one in mine and the only problem has been a bad center support inside the tranny causing 1st and reverse to come on at the same time That was fixed under warranty by the transmission shop. Other than that, no problems with actually installing it. Used my stock driveshaft, just changed the slip yolk to a TH400 slip yolk, bought the Spohn crossmember and torque arm, used a poly trans mount and a B&M trans cooler.
I bought the TH400 cause the engine plans at the time included a 454 but changed my mind to stick with a 350 putting out about 700 hp on the bottle The transmission should be able to take more of a beating I can ever throw at.
Jake_92RS
Jan 28, 2020 10:37 PM
dyeager535
Aug 28, 2015 08:10 AM
michealleger
Aug 26, 2015 03:29 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Fronzizzle
Aug 9, 2015 01:15 PM
