Dana 44 U-joint
Old Jan 28, 2003 | 06:41 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Dana 44 U-joint
I was able get a great deal on a Dana 44 and after some reading found that I am going to need a new 1310 conversion U-joint for my driveshaft. The problem is that one post I read said I will need a Neapco 3-3130 or a Precision 372 U-joint and another said Precision 369. Which one do I need? Also where do I pick these up?
Old Jan 29, 2003 | 10:32 PM
Mark 89Formula's Avatar
SLP told me to use the Precision 372 or Nepco equivalent when I bought my Dana 44 from them. I picked up one from the local auto parts; it was a stocked part. Works fine with the LS1 driveshaft I installed at the same time.
Old Jan 31, 2003 | 09:56 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Precision #369 is what you'll need if you have a factory aluminum driveshaft. #355 is what you'll need elsewise. I'm pretty sure #372 is just the "heavy duty" version of the #355.
Another thing you'll probably need (PITA for me to find) are U-Bolts. I *believe* they are part number Spicer #2-94-28X ...I'll have to double check though. I also had to grind them down a bit for them to slip past the weld on the driveshaft.
Old Feb 2, 2003 | 02:18 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Will any of these work with a steel driveshaft?
Old Feb 2, 2003 | 08:56 AM
Car: '89 IROC-Z
I'm pretty sure #355 and #372 do although I can't tell you for certain. You'll just have to buy them and check if they dont fit take 'em back.
Old Feb 2, 2003 | 09:05 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Tell them you have a 92 Z28 with the aluminum DS. That will get you the right u-joint. Thats what I had to get when I got the AL DS for my RS with the 1o bolt. The bearings were a #6 and a #3 IIRC.
Kat
Old Feb 2, 2003 | 02:13 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Kat
The dana 44 has a different yoke then the 10-bolt rear does. The dana 44 uses a #1310 size yoke. I was wondering what conversion universal joint I need to use the stock steel driveshaft with a dana 44.
Old Feb 2, 2003 | 03:25 PM
JERRYWHO's Avatar
For a steel driveshaft use
Jerry
sailtexas186548
Jan 19, 2016 12:21 PM
Americanmouse
Sep 7, 2015 12:10 PM
Chevy3shitty
Sep 1, 2015 09:22 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
MENINBLK
Aug 5, 2015 11:58 PM
