B&M problem
Old Feb 6, 2003 | 08:56 PM
Bort62's Avatar
B&M problem
I would normalyl just search for this, But That's obviously not an option.
So yes, I am actually posting a question.
I have a B7M megashifter That was Given to me, and I installed in my car. It worked fine for a while.
Now I can only get it to go 1-R or 2-P
Seems like it might have slipped into 3 spd mode. How do I tell ?
I don't have the instructions.
Old Feb 6, 2003 | 11:04 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'm 90% sure you can get the instructions from B&M's website? Try seeing if the linkage loosened up under the car, and make sure that nothing in the console is blocking the shifter from moving. 3-speed mode uses a bolt in the shifter comb that keeps the shifter from going backwards, so unless someone broke into your car and put a bolt in there, it couldn't go into 3-speed mode on it's own.
Let us know what you find!
Old Feb 7, 2003 | 05:49 AM
BILZ88350's Avatar
bm
I agree with the above and I would only add to check the "finger" that goes into the ratchet gear grooves. This can be adjusted.It may have come loose and is jamming up the gear selection.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
