Mysterious Trans Pan Problem
Old Feb 9, 2003 | 12:13 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
Ok i check my car top bottom underneath on a pretty regular bassis... well today as i backed out of the drive i noticed a stain on the ground. well i jacked my car up and the wierdest thing... 5 of my transpan bolts were aobut a half inch to a quarter of an inch unscrewed. what the hell could of caused this? and should i be worried (of course i retightened them all)
Old Feb 9, 2003 | 12:26 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
They may have been to loose since it was last serviced. If you have not serviced it lately, I would go ahead and replace the filter and gasket and torque the bolts to spec.
Old Feb 9, 2003 | 02:26 PM
HamSpiced's Avatar
i assume its never been serviced... i plan on paying for a trans flush this summer so that will change the filter, gasket and what not corrct?
Old Feb 9, 2003 | 04:42 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Well, a trans service and a trans flush are two different things. A trans flush is better because you will exchange all 11 quarts of fluid. On the othe hand, a service will only replace 5 quarts of fluid, but you will have a chance to replace the filter, gasket and have a look in the pan. Most places that do the flush won't pull the pan off.
Old Feb 9, 2003 | 06:28 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
This can be a touchy subject with most transmission people but it's better to service the transmission by changing the filter then just having the system flushed. The little particals of debree like to fill the filter and reduce circulation. flushing the system with the conventianal method used today does not remove particals from the filter! I have a machine to flush transmissions but when it comes to my own car I drop the pan and do it the old fashion way of course it is nice just to suck the fluid out first.
Old Feb 9, 2003 | 08:52 PM
gearhead86's Avatar
Definitely change the filter and a fresh pan gkst and then have it flushed. We've got a flusher in our shop that has a sight glass and you would not believe the little bits of debris that you see go by! Its definitely worth having it flushed, that way you'll have nice clean fluid.
Old Feb 9, 2003 | 10:12 PM
HamSpiced's Avatar
alright can i do a trans flush by myself? is it hard what will i have to do? should i just all out and rebuild the trans as well? is that hard? how do i do it, what do i need? do i need **** to rent? i ask about rebuidlign cause more and mroe recently as i shift from drive to reverse it takes longer and longer to engauge.
Old Feb 10, 2003 | 12:20 PM
IROCBandit's Avatar
i just had the same problem with mine except i lost the two bolts that held on the little bracket for the shifter cable. i kinda figured out something was wrong when the car was stuck in drive, oh well 5 minutes later problem solved
84z96L31vortec
Aug 20, 2017 12:16 AM
maroe624
Apr 16, 2017 08:29 AM
mizz0313
Aug 12, 2015 06:45 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
