Used T56 condition?
Old Feb 11, 2003 | 12:48 AM
CheezX's Avatar
Used T56 condition?
I'm going to be picking up a T56 setup out of a 95 Camaro. It also has a Centerforce clutch.
Generally in what kind of condition are these things? I don't want to put it in the car and have to take it out too soon after. What is usually worn out? I'm going to open it up before buying it to check, just wanted to know what I should look for.
Old Mar 6, 2003 | 02:47 AM
82suped-up-coupe's Avatar
little late I know, but reverse is a big issue :P
Old Mar 6, 2003 | 07:41 PM
CheezX's Avatar
reverse is fine great actually. 4th gear sucks though. stupid CAGS and retard GM engineers
Old Mar 6, 2003 | 11:20 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
cags shouldnt matter unless you are running this behind an LT1 WITH the LT1 pcm. your stock 3rd gen ecm has no idea cags is there and will ignore it. youll be fine, trust me , ive done it.
good luck !
Old Mar 6, 2003 | 11:35 PM
CheezX's Avatar
yeah, I know. The 4th gear synchro is worn more than the rest because of CAGS in the previous car.
Old Mar 7, 2003 | 11:01 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
ahh, i misread your other post, i get it now.
Old Mar 10, 2003 | 12:59 PM
xanax's Avatar
make sure the output shaft turns when you have it in all gears and you turn the input shaft.
Old Mar 13, 2003 | 02:27 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
whats a CAGS? eh..
Old Mar 13, 2003 | 12:41 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
Originally posted by Kingtal0n
whats a CAGS? eh..
Computer Aided Gear Select...
under certain conditions (ie "economical driving") the CAGS system will activate solenoids which will close gates to keep you from shifting into 2nd or 3rd gear. it forces you to go from 1st to 4th. it was done for EPA/gas mileage stuff. easily overcome by using a CAGS eliminator (but not needed unless you have the 4th gen computer in the car as well)
all 4th gen M6 cars had this, as well as corvettes, i believe.
Old Mar 13, 2003 | 02:52 PM
v8unleashed's Avatar
that has GOT to be annoying
Old Mar 13, 2003 | 04:43 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
thus the creation of a CAGS eliminator!!
Old Mar 15, 2003 | 11:58 AM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
For more info on T56 swap. Im sure you've read it though.
http://www.skulte.com/T56.html
Old Mar 15, 2003 | 12:56 PM
CheezX's Avatar
Oh I did the swap 3-4 weeks ago now. What that web page didn't mention is that the VSS connector is different and that you should get it from the donor car unless you want to go to all the parts stores and order the wrong one a million times and then finally go to the dealer and pay their crazy jacked-up prices.
Old Mar 16, 2003 | 02:40 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
A little tip on the VSS connector is to use a coolant temp sender plug of a thirgen (v6 or v8) or any other GM 80's model. It's the same plug (Easily swiped from the j-yard )
Old Mar 16, 2003 | 07:59 PM
Supercharged84Z's Avatar
Car: 1984 Camaro Z28
Engine: 350 CID
Transmission: Beefed up 700R4
hey guys..i was thinking about putting in a T56 but my uncle was telling me that my computer wouldnt work with the T56..i have an '84 car that is carbureted(computer controlled q-jet)..does anyone know what the T56 would do with my computer?!?!? im kinda stumped
Old Mar 17, 2003 | 11:37 AM
black84-6spdz28's Avatar
it dont matter if you 84 has a computer or not.....mine had one and i have a t56 in my car...the computer only controls spark and the carb
Old Mar 18, 2003 | 07:39 AM
CustomCarShop's Avatar
T56 Conversion in a 700R4 Camaro
I own a '88 IROC-Z and it had a 700R4 in it. I took it out a couple months back. Im putting a T56 into it as soon as I get one. I am in the process of removing the interior for the conversion to, all I have left os the center console & the carpet.
I was wondering if anyone has any pictures of doing this swap, actually what I need is a picture of where to cut the hole,in the floor? Or are there markings already?
Old Mar 18, 2003 | 02:29 PM
Engine: 350 CID
from what ive read, you only have to extend the existing hole back two inches, but i may be wrong
Old Mar 19, 2003 | 05:08 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
he had an auto to start with, no hole there. i just measured my tranny from the bellhousing to the shifter, than measured that same distance from the engine block to back and made a mark at that distance and started cutting away. worked perfect.
Buggy Disaster
Sep 22, 2015 01:15 PM
Numbah-1
Sep 12, 2015 08:57 PM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
Jetmeck
Sep 4, 2015 12:29 AM
tonys91rs
Sep 2, 2015 07:07 PM
