Just finished with 2.73 to 3.70 swap.
Car: 87Z
Engine: ?
Transmission: A4
I have three things to say about this swap
. One full gear incress is nuts. The danm thing will cut the tires loose at 30 mph. I have one problem though. When I turn the car to the right I get this terable howl, from what seem like the front driver side tire. It goes away with brake pressure. Any ideas?
. One full gear incress is nuts. The danm thing will cut the tires loose at 30 mph. I have one problem though. When I turn the car to the right I get this terable howl, from what seem like the front driver side tire. It goes away with brake pressure. Any ideas? Senior Member
Car: 1989 IROC-Z
Originally posted by 25THRSS
the gears could be set wrong, this could cause the sound.
interesting...
Originally posted by NJITIROC
the sound is from the right front he said. so i doubt it has anything to do with the gears. unless the sound is really from the back, and it just sounds like its from the front.
interesting...
interesting...
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Hey, new87, I am about to do the exact same swap 2.73->3.70.
As far as the howling, maybe the car is no longer in alignment since you swapped rears.
All's well though.
