Best Clutch for the money???
Old Feb 11, 2003 | 10:06 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
I installed a new clutch disc when I installed my new motor a little over 6,000 miles ago. I got an o.e. replacement Centerforce.
Well, the new motor has some power and the clutch is pretty much shot already. Now it'll catch on the launch but it slips really bad when I shift. If I don't launch it, and just shift at 5,500 rpm, it grabs and the tires break loose. So basically, as sson as it heats up, it slips like a bastard.
What is the best all around clutch for a motor with about 300 h.p.?? Centerforce dual friction?? Or are there cheaper/better alternatives??
Old Feb 11, 2003 | 10:15 PM
laiky's Avatar
IMHO CFDF
Old Feb 11, 2003 | 10:19 PM
Scott C's Avatar
CF DF =
Old Feb 11, 2003 | 10:46 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Ok guys....
What about RAM?? How bout ZOOM???
I really don't want to spend all that much, but I want a decent clutch that isn't gonna crap out on me with 300 horsies.
Edit: I guess 270 bucks isn't that bad. I was hoping to spend only about 200 though.
Old Feb 11, 2003 | 11:08 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
I definitely agree with the others on the Centerforce Dual Friction! :rockon: I had a RAM in my '69 GTO when I first got it put together and it slipped like heck every time I got on the gas! I put a Dual Friction in it and it was a huge improvement (still slipped because of a rear main leak though). I put a DF in with my new motor and T-56 in the TA and it's perfect! grabs great! I don't have any experience with ZOOM, but I would steer clear of RAM, and I would definitely recommend a CF DF! BUT, MAKE SURE you get the flywheel resurfaced and follow Centerforce's breakin procedure, because I have heard of premature failure (not hugely premature) because of not following their instructions (the real big one is resurfacing the flywheel, from what I've heard). Anyway, that's my $0.02 FWIW, but some people have had bad experience with Centerforce too, so it's up to you in the end (obviously lol )
-Paul
Old Feb 12, 2003 | 09:20 AM
87 B4Z's Avatar
Mcleod is THE best clutch you can get.
Old Feb 12, 2003 | 10:05 AM
quadgoat's Avatar
Car: 1992 Firebird
I meant to say this in my post but forgot to, lol. Yeah, 270 is a chunk of change, but be glad that you aren't shopping for a clutch for a t-56....I paid about 550 for mine Oh well, ya gotta do what ya gotta do I guess!
-Paul
Old Feb 12, 2003 | 01:40 PM
MikeDwhoROCZImports's Avatar
-Paul
Heh....yeah I thought my CFDF was expensive...until I bought my ACT2600 for my eclipse. $395...and I couldn't install it myself like I could in my IROC (now way in hell I'm going to try to install a clutch in an AWD car without a lift in January in New England).
Clutch plus install was about $900
Old Feb 12, 2003 | 08:38 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Well then.....
I guess I'm not feeling too bad after all. I'll probably get the centerforce, they seem to be the most widely used.
Hey 87 B4Z:
How much do the McLeod clutches go for??
Old Feb 12, 2003 | 09:07 PM
Re: Well then.....
Yeah the CFDF can handle more than what you'll need with 400+hp and RWD...unless you're running slicks and are in the low 12's high 11's you should be fine.
Old Feb 12, 2003 | 11:41 PM
87 B4Z's Avatar
Re: Well then.....
Hey 87 B4Z:
http://www.thunderracing.com/index.c...ategoryid=1102
Old Feb 13, 2003 | 12:53 AM
BORLAZ06's Avatar
i agree with some of you people...the CFDF aint that bad if you break it in properly. lol. for the price you cant go wrong and it hold up quite well for the average thirdgen.
Old Feb 16, 2003 | 03:08 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Checked out Thunder Racing....
Ok there are the SPEC clutches good for 700 horse, or the McLeod for at least 500 hp.
What is that max I can throw at the Centerforce DF??? 500???
Old Feb 17, 2003 | 12:32 AM
laiky's Avatar
I wouldn't be asking " What is that max I can throw at the Centerforce DF" I would be asking " what makes a clutch capeable of handling 500 or 700 HP"
I don't know how much power it can handle, there are too many factors involved. What i do know is that it is a great clutch, it drives great and feels great. Smooth engagment, linear and locks up tight. I figure my combo is good for at least 400 HP 400 Ftlb. It has never given any indication its being stressed.
Old Feb 20, 2003 | 12:27 AM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Good...
That's all I needed to know. I'm not planning on a huge horsepower setup, but I really like to get on it when I want to...which is a lot, without burnin' the clutch up.
Old Feb 22, 2003 | 10:17 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I'd go with the Spec Clutch kit. Stage 3 Kevlar, I believe is a decent one.
I had the CenterForce Dual Friction in my car, but I didn't have that much power, about 250rwhp. It held up fine on my setup.
But I have heard that the quality of the CF clutches has gone down since I got mine in 2000.
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
