How hard would this be?
Old Feb 21, 2003 | 10:47 AM
Jasper89ROC's Avatar
How hard/easy would it be to put a ford9" and a muncie/jerico 4-speed manual in a 3rdgen? With the 9" would i still be able to run a rear swaybar? Do I need to buy a certain type of 9" to fit the thirdgen? Sorry for the dumb questions im not to knowledgable on swapping.
-Mark
Old Feb 21, 2003 | 11:12 AM
ede's Avatar
ede
if you aren't that knowledgable it may be best to not attempt it. buy a 9" for a thirdgen f body. as for the trans manual linkage always seems to be a sticking point with most people. better to look at a t56 or tremac.
Old Feb 21, 2003 | 01:01 PM
kevinc's Avatar
Car: 1982 Z28
Re: How hard would this be?
Originally posted by Jasper89ROC
How hard/easy would it be to put a ford9" and a muncie/jerico 4-speed manual in a 3rdgen? Sorry for the dumb questions im not to knowledgable on swapping.
-Mark
If you're not knowledgeable on swapping, I'd say it would be hard (for you) to do swapping.
Old Feb 21, 2003 | 01:04 PM
I have swapped a rearend in before, and i could go w/ a 12 bolt if I need to depending on how much I find one for. Plus my dad will be helping and he has done all this before. And I would really like the 4-speed cause its goin behind a BBC. What problems to people have with the linkage?
-Mark
Old Feb 21, 2003 | 01:10 PM
kevinc's Avatar
Car: 1982 Z28
The clutch linkage requires cutting on the firewall and fabrication of a pivot point...newer transmissions use hydraulic clutches which keep the hacking to a minimum. Running a big-block doesn't leave much room to squeeze in a Z-bar or whatever clutch linkage you're considering.
For the shifter linkage, it's just more floorpan cutting which some people don't like. Swap in a T56 from an LT1 car and you'll be cutting anyway so doesn't seem so bad to me.
As for the rear-end, whether 12-bolt or 9", there isn't a directly-transplantable option from the junkyard. You need to add lower control arm brackets, spring perches, and the torque arm mount. Aftermarket bolt-in options from Moser and others exist but cost upwards of $2000 complete.
RedLeader289
May 28, 2019 01:47 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
loud91rs
Oct 5, 2015 10:05 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
