Borg Warner 9 bolt code
Old Feb 22, 2003 | 06:18 PM
gcore45's Avatar
Car: '91 RS
Engine: 5.7 tbi
Was the 9 bolt posi a code C or T on the diff tag? Mine is too rusted to read.
Old Feb 22, 2003 | 09:30 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
Did you get the axles?
Old Feb 22, 2003 | 10:03 PM
gcore45's Avatar
Car: '91 RS
Engine: 5.7 tbi
yes I did. They look great. I posted a comment in the classified section under misc.
Old Feb 23, 2003 | 01:57 AM
drain89's Avatar
Very good. Thanks again for your business. As for the codes on the tag, I don't know. How I check if the tag is unlegible or there's no sticker with the RPO codes is to remove the cover and look on the side of the ring gear. It should have the ratio stamped on it. AFAIK, the only ratio 9 bolt that was available as a one-legger was the 3.08 and maybe some 2.77's. All of the G92 cars were posi and had the good 3 series ratio's (3.27, 3.45, and 3.70).
Draino.
Old Feb 23, 2003 | 09:22 AM
gcore45's Avatar
Car: '91 RS
Engine: 5.7 tbi
This came up after a trip to Autozone looking to price axle bearings. The clerk indicated the computer needed to know if the tag on the rear indicated a C or a T. He stated the notes referred to whether it was a chevrolet or pontiac rear end. He looked at me funny when I told it was a 9 bolt borg warner from australia. I'm not slamming autozone, but I don't have the info to fill in the blank for him.
Old Feb 23, 2003 | 11:16 AM
drain89's Avatar
I know what you're talking about now. The best thing to do since you can't read the tag is to remove the old bearings and take them to the auto zone with you that way they can get the number off of it and then you can compare the 2 side by side.
Old Feb 25, 2003 | 03:02 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Axle bearings are Timken set 9. You can use tapered or straight and all 9 bolts use the same axle bearings!
Miles
Diff Solutions
www.9bolt.com
Old Feb 25, 2003 | 05:38 PM
drain89's Avatar
I think Timken set 9's are tapered but if you have a choice of either I'd go with tapered.
Old Feb 26, 2003 | 04:59 PM
gcore45's Avatar
Car: '91 RS
Engine: 5.7 tbi
With the installation of replacement axles, should I replace anything else?
Old Feb 26, 2003 | 06:03 PM
drain89's Avatar
I would replace the axle bearings and seals, replace the oil with a good synthetic fluid. Now would be a good time to buy a shim kit and "tighten" your posi. See the above thread for instructions. Just be sure to reference what orientation the shims and bearing caps were for the left and right journals and you'll be fine!
Old Mar 1, 2003 | 02:34 PM
gcore45's Avatar
Car: '91 RS
Engine: 5.7 tbi
How about carrier bearings?
Old Mar 1, 2003 | 04:13 PM
drain89's Avatar
If I was to go that far I'd buy an overhaul kit and replace the pinion bearings too. The carrier bearings are probably fine, but pinion bearings are know to wear out and cause the demise of a 9 bolt rear. I listed several sources for parts in my other post titled 9 bolt info. Reider Racing would probably be the cheapest for a complete overhaul kit with Timken bearings. Ratech would problably be the cheapest for individual parts.
Good Luck.
hectre13
Dec 11, 2023 08:14 AM
theshackle
Sep 17, 2020 08:26 AM
AussiePr0nCar
Mar 6, 2020 04:04 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
fasteddi
Sep 2, 2015 10:29 AM
