85 into an 87 TH700R4 "Wiring"
Old Feb 27, 2003 | 09:41 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
I've got a built 700R4 sitting in my garage from my '85 IROC. I plan on putting it in my '87 IROC with my 350 (replacing it's 305).
I have to swap the speedo gears (don't know what my '85 was setup with)... and I've been told that the '85 and the '87 700R4s each use a different kind of wiring. Each have a 4 prong plug, but each prog is used differently by the computers per year.
I was told I have to pop the pan of each.... and just swap wiring harnesses.
Is this true? And does anyone have any more info for me than that before I start ripping my transmissions apart?
Old Mar 1, 2003 | 09:15 PM
Come on techs?!?!?!?!
Old Mar 1, 2003 | 11:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They should be the same.
Old Mar 2, 2003 | 08:36 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
It should work about the same. Most of the pins in the connector are for the same purpose (4th gear switch, TCC, etc...) but the actual wiring in the tranny may vary. However, this should not effect operation. Sometimes the TCC can be grounded through a temperature switch, a gear switch, etc... It all varies on model, but like I said, it shouldn't effect operation.
Cleotiz
Jan 6, 2018 08:56 PM
camaronils
Sep 20, 2015 02:57 PM
LilJayV10
Dec 18, 2001 06:20 AM
Ward
Nov 26, 2001 08:02 AM
Ward
Nov 26, 2001 07:49 AM
