leaking trans 700-r4
Old Mar 2, 2003 | 09:36 AM
ngafp's Avatar
Car: 1992 Z28
Transmission: 700 R4
Does any know if I take out the speed sensor(need to replace O-ring) if the majority of the fluid will come out or will just a little of the fluid will come out. I am trying not to get a total bath here.
Any suggestions?
thanks
randy
1992 Z28
L98
Old Mar 2, 2003 | 09:53 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You may lose up to maybe a half quart. There is fluid there, but not much.
Old Mar 2, 2003 | 12:10 PM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Teds92rs once told me that when you remove your vehicle speed sensor, try to jack up the car from the rear axle for 2 reasons:
1. You may be able to have more room to move around down there while you do your job.
2. If you jack up the vehicle from the back, the trans fluid will flow toward the front of the transmission, meaning you will not lose that much fluid if any at all.
I hope your operation goes well, good luck.
Old Mar 4, 2003 | 08:27 PM
ngafp's Avatar
Car: 1992 Z28
thanks
thanks guys everything worked out great. no mess at all.
thank you
randy
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
wayshegoes
Aug 17, 2015 12:00 PM
mizz0313
Aug 12, 2015 06:45 AM
Exxon Limited
Aug 9, 2015 08:13 PM
