Tranny cooler lines???
Old Mar 9, 2003 | 09:50 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Which line is the return and which is the incoming?
Is the line coming in to the top of the radiator the fluid from the trans, or is it the cooled fluid going back into the transmission?
Thanks for the help,
Old Mar 9, 2003 | 10:11 PM
Benny's Avatar
Incoming should be bottom and return to Trans is top.
Old Mar 10, 2003 | 05:43 AM
ede's Avatar
ede
benny it sounds to me like you said both top and bottom lines to the trans are in.
top is out bottom is in IIRC
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Stryker412
Sep 7, 2015 09:11 AM
TBRays98
Sep 6, 2015 05:05 PM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
