Tremec-5 Swap
Old Mar 11, 2003 | 07:03 PM
91TPICamaro
Guest
Posts: n/a
Tremec-5 Swap
I currently own a 1991 Z28 LB9 700-R4, i built a 355ci L98 motor for it and i would like to change the tranny while im at it for a tremec 5, i ws just wondering how much labor and $$$$$ would be involved in this. any help is appreciated.
Old Mar 11, 2003 | 10:42 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
Re: Tremec-5 Swap
swapping in a tremec 3550 or TKO from fortes is a pretty easy job, even if you dont have a lift it shouldnt take more than a day or so to do.
you need to buy the kit which comes with the transmission, shifter, adapter plate (bolts between trans and bell), speedo drive, slip yoke, adapter u-joint, cross member spacers etc.
its a pretty straight forward installation, i would go with an aftermarket shifter like a pro 5.0 though.
Do a search on this, its come up alot of times before, you could find some good information.
also, check out http://www.fortesparts.com
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
