I need help, and lots of it.
Old Mar 13, 2003 | 09:27 PM
echo5blud's Avatar
Car: 1986 Z28
Engine: 305...350/383 in progress
Transmission: 700r4...fresh rebuild
Well, I bought an 86 Z28 yesterday. I bought it for $800 knowing that it would be a fixer upper type deal. Well it was having a smoking problem that turned out to be a leak in the transmission. I now need to replace the front seal on my transmission. I've been told by several people this is a pretty easy thing to do. Could someone break this down for me. I'm pretty much clueless when it comes to transmissions.
Old Mar 14, 2003 | 05:42 AM
ede's Avatar
ede
pull the seal and put the new one in, it's that easy. i use a slide hammer seal puller to remove seals with, saves a lot of time and effort. you do have to r&r the trans, but you knew that right?
Old Mar 14, 2003 | 11:39 AM
kevinc's Avatar
Car: 1982 Z28
Re: I need help, and lots of it.
OK...just making sure I understand...you knowingly bought a fixer-upper but don't know how to fix. And that made sense to you because....?
Old Mar 14, 2003 | 09:17 PM
Uncle Skeletor's Avatar
Car: 1991 Camaro RS
Engine: 350, Edelbrock Pro Flo efi
Axle/Gears: 4.10 on a torsen diff
Check the cooler lines. A friend of mine had a leak that smoked real bad, but it was the the cooler lines dripping on the exhaust. It always started smoking at the most opportune times, like when we were at drive thru windows or waving at some girls or something messed up like that.
Old Mar 14, 2003 | 11:46 PM
echo5blud's Avatar
Car: 1986 Z28
I knew it was a fixer upper....transmissions are something I'm not good with.....I am good with other things.....I don't understand how transmissions work......so I prefer to deal with engine problems or cosmetic problems......
Old Mar 14, 2003 | 11:57 PM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
I think it's a great idea - how else does someone learn to fix a vehicle....?
Old Mar 15, 2003 | 08:05 AM
kevinc's Avatar
Car: 1982 Z28
I don't disagree that a project car is a great thing, do-it-yourself is a great learning process. It's the people who won't buy a book, thinking they can learn everything here if they TTT enough, that don't add up.
Old Mar 15, 2003 | 09:06 PM
echo5blud's Avatar
Car: 1986 Z28
I've got the chiltons. ....It covers the removal....it also says a bit about putting it back in......It's in......I'm having a little bit of trouble getting the dipstick back in......I've had better days.....I don't know for sure, but if I have any more transmission problems it might go see a professional......
Old Mar 16, 2003 | 04:02 PM
echo5blud's Avatar
Car: 1986 Z28
I did it. I got the transmission out...the seal changed then I got it back in. No more leaking transmission for me.
jhawkeye
May 25, 2022 06:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
Steve78LT
Feb 24, 2016 12:15 AM
mustangdmurder
Aug 21, 2015 07:17 PM
BewleyBizzIROC
Aug 14, 2015 02:52 AM
