84 700R4....what are the four wires that go to the trans....also question on lockup
Old Mar 16, 2003 | 12:43 AM
CamaroX84's Avatar
I am in the process of ditching my computer on my 84 Camaro to go to a non-computer setup. There are four wires that lead to the trans. What do these do? Are they only for converter lockup? Also, I know the 84 model uses a speed sensor located behind the speedometer, which is plugged into the dash harness. I know this affects converter lockup. Will the lockup work without the computer hooked up, or does the signal not pass through the computer at all? Please remember this is an 84 carbed car. Thanks in advance.
Old Mar 16, 2003 | 10:54 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Re: 84 700R4....what are the four wires that go to the trans....also question on lockup
I have a 84 Camaro and removed the ECM.
The 4 wires are for the Convertor lock-up. If you ditch the ECM you would have to get a lockup kit for it to work.
there are cheaper way to make a lock-up switch but here is on that 700r4.com sells:
http://www.700r4.com/getpart.asp?cat...20Parts&id=455
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
