T-5 clutch wont disengage gears, hydro clutch replaced
Old Mar 23, 2003 | 05:16 PM
TBIfly's Avatar
As stated similarly in another post:
I have a T-5 on my 91 RS.
Occasionally, randomly, when i press the clutch in I hear a chattering as if the clutch isnt fully disengaging. I replaced the slave and master cylinders, and checked all the lines, and I am getting the minimum .57 inches of clutch fork travel required for my 5.0 TBI car. Another problem is that sometimes I cannot get my car into 4th gear, to do so i have to take the shifter to the 2nd gear path, then 3rd, then it will go into 4th
What else could be the problem?
-not enough bleeding?
-worn throwout bearing?
-worn Pressure plate?
-worn driven disc?
any help and insight would be greatly appreciated. I will answer any questions you have if that will help you give me a more educated answer.
BTW, I replaced the driven disc about 3 yrs ago with a RAM, although that is all i replaced and did not have the flywheel turned.
-blain
Old Mar 23, 2003 | 08:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like your pilot bushing is non-existent. It's a 75¢ part that has caused many a $450 clutch job to fail to fix the malfunction. It is in the end of the crankshaft.
Old Mar 23, 2003 | 09:27 PM
TBIfly's Avatar
RB
Pilot bushing you say? that's the first time I have ever heard that, and im not discounting the possibility, but most every one else responds with a worn Throwout bearing.
Could you tell me why you think its the pilot bushing between the flywheel and the crankshaft?
-blain
Old Mar 24, 2003 | 06:34 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Because if it's bad, the clutch gear can wobble all around, and the clutch won't stay running parallel to the flywheel and flex plate. It's the only thing holding the front of the clutch gear in line with the crank. And since 4th gear is actually the back side of the clutch gear, if it's busy wobbling, it's impossible for the synchro to work right, which makes it particularly hard to get into 4th.
"The simplest explanation that fits all the facts is usually the right one".
— Occam, ancient Greek wise man, from days even before automatic transmissions
Attached Thumbnails T-5 clutch wont disengage gears, hydro clutch replaced-pilot-bearing-clutch-gear.jpg
jklein337
Sep 19, 2018 06:23 PM
redmaroz
Aug 16, 2015 11:40 PM
mizz0313
Aug 12, 2015 06:45 AM
rsrmoore
Aug 7, 2015 08:44 PM
