u joint straps at pinion yoke...are there ANY aftermarket ones?
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i want to replace the stock U-Joint straps that hold the rear U-Joint to the pinion yoke with aftermarket ones.
i cant find them ANYWHERE. i figured the next best thing was brand new ones (and new bolts) from GM, so i went and got them.
moroso makes U-Joint "girdles", but none are available for the 10 bolt.
what do you guys think? has anyone seen beefier ones? i mean, maybe they are not necessary. probly not, considering that there are NONE available from the aftermarket that i have seen.
any info would be great. thanks.
-brian
-brian
Car: 1991 Camaro RS
Originally posted by ede
try moroso
try moroso
any other suggestions?
-brian
Car: 04 GTO
Transmission: M12 T56
If nooone here chimes in, might want to check some better LS1 boards too, like ls1tech.com. Some of those max effort 4th gen guys run/ran 10 bolts into the low 10s and 9s just for the power/weight savings.
Car: 1991 Camaro RS
good call ...thanks for the advice.
-brian
Car: 1991 Camaro RS
it's be real easy to make some, if you can't find any start looking for someoen with a mill
Find out who to talk to to get access to the shop yourself. Likely they'll just make you go through a brief instructional session and you're set. Usually it is intended for school work though, but you can figure out how to relate it I'm sure.
sjorgens
Oct 1, 2015 07:54 PM
