Swapped T-5 for Tremec 3550... Got lots of problems now.
Old Mar 31, 2003 | 09:08 PM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Transmission: Tremec 3550
ok I swapped out my t-5 for a tremec... Now I'm having strange vibrations all over. When I first start the car it will vibrate so bad the dash pad bends... it actually took out one of the screws. But as soon as I press in the clutch it goes away, let out the clutch and come back but at about 10% strength.
Next The transmission will make a whining noise like it is spinning if the clutch is depressed, and the tranny is in neutral. Put it in gear and it goes away.
Lastly the car will make a strange grinding/rumbling sound if I take off hard or cruising around with the gas petal down enough to stay at a steady speed. Let off completely or stomp on it and it will clear up.
Could this be rear motor mounts? U-Joints? Drive shaft? I just replaced the clutch, pressure plate, Pilot bushing, and throw-out bearing.
Oh by the way this is my first post so I'm kinda new to this
Old Mar 31, 2003 | 09:16 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
you put your Throw Out bearing in wrong for one thing......
Old Mar 31, 2003 | 09:20 PM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Nope.. I always worry about that so I end up checking it 3 or 4 times. It goes into gear good and shifts fine.
Old Mar 31, 2003 | 09:52 PM
you sure, or are you just lying to yourself ?
Old Mar 31, 2003 | 09:54 PM
i just noticed that you also replaced your clutch assembly
did you get your flywheel cut?
i bet your getting some chattering from a glazed flywheel if not
Old Mar 31, 2003 | 10:03 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Question,
Where did you get the Tremec from?
Old Mar 31, 2003 | 10:07 PM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
No I did not... But it has less than 1000 Miles on it. I suppose that could be the start up problem, but could that also cause the strange vibrations during acceleration and cruise?
Old Mar 31, 2003 | 10:08 PM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
I got the tremec from Fortes Parts. Full kit.
Old Apr 1, 2003 | 05:26 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Stock bellhousing or aftermarket scattershield? Did you replace the pilot bushing by chance? Did you replace the clutch disc?
Old Apr 1, 2003 | 11:54 AM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Re: Swapped T-5 for Tremec 3550... Got lots of problems now.
Stock bellhousing with adapter.
Old Apr 1, 2003 | 12:28 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
You might have to pull the tranny and get the bellhousing and the adapter dialed in, or get an aftermarket bellhousing and have the same done. Sounds to me like the input shaft is out of line. If it actually is out of line, it WILL eventually destroy that Tremec. Do yourself a favor and STOP DRIVING IT until you get that problem checked out and fixed.
Old Apr 1, 2003 | 01:33 PM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
I havn't even really started driving it. I drove it from the place I was working on it back to my house. So I'm gonna head back over to the shop tonight and check it all out. I was starting to think it might be that the tranny was not quite aligned. Thanks for the help guys, and any more info would be very helpful.
jhawkeye
May 25, 2022 06:33 PM
Grant2k
Jul 10, 2018 04:01 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
sreZ28
Aug 14, 2015 07:48 PM
