Problem after installing TransGo kit
Old Apr 2, 2003 | 01:17 PM
LT1guy's Avatar
Car: 1987 Trans Am
Now there is no reverse, or neutral...park works, but every other gear is a drive gear. The shift linkage was a little tough bolting up (binding), and it was pretty late (and I'm sick) at night when I did that part...so hopefully, I just messed up the linkage. Any ideas?
Old Apr 2, 2003 | 05:59 PM
ArrioZ28's Avatar
If this is a 700R4, sounds like the little z rod that connects the manual valve to the selector shaft is not connected. Its real easy for that little rod to disconnect when trying to bolt up the valve body. You need to drop the pan and have another look at your manual valve linkage.
Old Apr 3, 2003 | 07:28 AM
LT1guy's Avatar
Car: 1987 Trans Am
Its a 700R4...thanks, I'll try that when I get home. I thought it might have been a shift linkage problem, but I don't think so now.
Old Apr 3, 2003 | 08:01 AM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
I'm still learning, so I'm going to ask the dumb questions...
manual valve linkage... thats the rod that was right next to the Detent, right?
http://www.bernd-hoffmann.com/Mein_U.../700-R4_37.jpg
Figure 700-R4-72
So using the pic...you believe 3 unhooked from 4?
When this unhooks the car selector will work, but it will not tell the valve body what to do right, because it does not move the valve... I wonder why It had park and drive though?
Old Apr 3, 2003 | 11:34 AM
ArrioZ28's Avatar
Figure 700-R4-72
Yes, that is the little Z rod I was talking about. The reason that you still have park is that the inner detent lever is still hooked to the park rod. The park rod is the long rod that goes all the way back the rear of the transmission and locks the output shaft when in the park position. The manual valve is just sitting there in the drive position an not hooked to anything. It see's "Drive" (or D1, D2) all the time.
Old Apr 3, 2003 | 11:42 AM
LT1guy's Avatar
Car: 1987 Trans Am
I hope you're right...we'll find out tonight I guess! Should be a simple enough fix. Thanks for your help ArrioZ28!
Old Apr 3, 2003 | 12:24 PM
redraif's Avatar
Yes, thanks for your help. I'm glad someone could clue us in to the problem. I know we hooked it up, but I never double checked it after that. We called TransGo last night and could get no one on the phone. Tech was too busy. Finally today we got thru they said the same thing you did. Let's hope the rest of the install is correct! I know I triple checked everything else!
Old Apr 4, 2003 | 07:49 AM
LT1guy's Avatar
Car: 1987 Trans Am
Its fixed! Arrio Z28, you were right. The linkage rod was hanging down, must have come loose when the valve body was put in. The car drives much better now, and all gears work great (though it didn't want to shift at first...this cleared up in a minute or so on its own). We are going to install another washer though to firm up the shifts some more; two aren't enough with this car (2.8 V6).
Old Apr 4, 2003 | 08:54 AM
redraif's Avatar
Thanks so much!
Old Apr 4, 2003 | 11:33 AM
ArrioZ28's Avatar
You guys are very welcome, glad it worked out and your trans is working again
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
dhonda200
Aug 11, 2015 11:50 PM
drathaar907
Aug 6, 2015 04:20 PM
