Do I need to buy a torque wrench?
Old Apr 4, 2003 | 08:51 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
I am in the middle of swapping a not broken t5 into my car and was wondering If I needed to worry about torquing the bolts (for the flywheel and pressure plate) or can I just screw 'em down with an impact and roll with it?
Old Apr 4, 2003 | 10:02 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
It's a very usefull tool and can come in handy in the future. Id reccomend getting one even though its not needed for a clutch its better to use one then not. Autozone sells decent one with a liftime warrenty for $25 and they are accurate and made by Great Neck who uses Craftsmen's old design patterns so we can draw some conclusions from that.
Old Apr 4, 2003 | 10:13 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Don't put a clutch on with air... use hand tools. Tighten the bolts around the clutch progressively so that the clutch doesn't get bent. They're 3/8"-16, so 35 ft-lbs or so (a pretty good arm with a 9/16"-5/8" box wrench, but not murdering them or anything) is about right.
Flywheel bolts should go to about 65-70 ft-lbs. If you know what your impact produces, it's OK to use it for those.
Old Apr 4, 2003 | 10:51 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yea, don't use an impact wrench... my friend just discovered that his flexplate in his '67 Mustang was put on with an impact wrench (old owner, what are ya gonna do? ) And from what i have heard, he still hasn't gotten it off.
Old Apr 5, 2003 | 03:42 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Well thank you all for your help. I think it is time to invest in a torque wrench.
BumpaD82
Feb 26, 2016 02:57 PM
88rscamar0
Sep 23, 2015 09:08 PM
abray1
Sep 10, 2015 04:53 PM
Jlanz55
Sep 8, 2015 11:28 PM
FormulasOnly
Sep 6, 2015 10:42 AM
