Built 10 bolt to built 9 bolt swap
Old Apr 6, 2003 | 02:20 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
I am currently running a 10bolt with Richmond 3.73s, Moser 28 splined axles, alum stud girdle/cover, zex posi, and 89+ brakes. I am considering selling the rear end for $600 and catching a factory '88 2.77 posi 9 bolt for $200 from a local friend.
The idea would be to switch the 9 bolt to 4.10s and make it as strong as it can be. www.9bolt.com Is this a cost effective swap for me considering strength to cost ratio? (How strong will the 9bolt be vs a 9", 12bolt, or dana 44 once it's built up?)
How would I handle the disk brake swap issue? (88 9 bolt to 91 10 bolt)
Thanks for any input!
Old Apr 6, 2003 | 02:38 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I don't think you will be able to get $600 for a 10 bolt. As far as rearend strength
Here is the order from strongest to weakest:
Ford 9'inch
GM 12 bolt
Dana 44
BW 9 bolt
GM 7.5 10 bolt
Old Apr 6, 2003 | 03:00 PM
JMatlock88's Avatar
Car: 1991 Formula
I was going to trade him $390 + his 9 bolt. That's not a bad deal for him considering the moser axles alone are $265+, the spohn brackets are $75, the alum stud cover is $150, etc etc. There is $1000 into this rear end.
Is that order with each one being built to the hilt? Probably not..
A built 10 bolt is significantly stronger than a stock 9bolt, espeically with any mileage. For him to change his 9bolt gears alone is $300. Stronger rear end with low mileage + new gear ratio for $390...not bad I'd say. I'm saying this because he is a friend and I'm not trying to rip anyone off.
Old Apr 6, 2003 | 03:45 PM
IROC of 88's Avatar
Car: 1988 IROC
Engine: See Signature
Transmission: B&M 700r4
I am the other part of thise deal.... i just wanted to be subscribed... anyways... lets get some good intelligent answers
Old Apr 7, 2003 | 09:49 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
If youre planning on swapping a 9 bolt 2.77 to a 4.11, be warned that the 2.77 carrier will not work. DiffSolutions is supposed to be working on a spacer to adapt the two, but a release date has not been set. Anyway, youre looking at roughly $820 for the ring/pinion/posi carrier package. You can get Moser axles for the BW and DiffSolutions is going to be releasing a support cover shortly. These prices add up quickly, but its not too bad considering its near impossible to find a 12 bolt or 9 in. for under $2500. The 9 bolt is slightly lighter than those two, but theres a lot of strength with that extra weight. Bottom line, if you can afford a 9in/12bolt, go for it, if not, (like me) go with the BW.
Terrell351
Jun 13, 2021 01:13 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
