What would my top speed be if
Old Apr 7, 2003 | 01:34 PM
IROCME's Avatar
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
I had:
323's
342's
or
373's
mods in sig for 86 LB9
Old Apr 7, 2003 | 02:49 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
way more than the speed limit
but my guess is , even with 3.73s you will run out of HP before you run out of gear.
Old Apr 9, 2003 | 08:49 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
With a mild build like that, i'd say you'd have the highest top end with the 3.73's because it probably wouldn't have the power to top out the 3.23 or 3.42s as easily as the 3.73s
Old Apr 9, 2003 | 08:55 PM
icecold's Avatar
Car: 1990 formula
Engine: 350 tpi supercharged
Transmission: 700 r4
speed -gear calculator
try this for your speeds it is what i used in selecting my rear end gears
http://www.f-body.org/gears/
pete
Old Apr 10, 2003 | 07:29 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Not too much different in any of those cases; the top speed of a car is limited by its aerodynamics much more than engine power, I doubt you'd find more than 5 mph actual top speed difference among the 3 ratios. The curve of HP vs speed increases fairly smoothly and linearly up to a point, then sharply turns upward exponentially; that point is pretty much the body's top speed. It takes an enormous increase in power to produce even a small increase in top speed for a given body.
Old Apr 12, 2003 | 06:10 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
You wouldn't happento know by chance what that point is on a 3rd gen firebirs and/or camaro would you?
Old Apr 12, 2003 | 09:11 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Seems to be in the 135-140 mph neighborhood, depending a little on the body's rake and height. I tend to discount anybody that says their stock one of these cars runs past 145 nph; I've never heard of anyone giving that monkey-spank with a radar gun or other accurate means of measurement as their standard, only their own speedo.
Old Apr 12, 2003 | 10:35 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
faster then a speeding ticket
Old Apr 14, 2003 | 05:17 PM
Pontiacman's Avatar
I've gotten my Formula up to 140 mph. 3400 rpm, with .62 overdrive and 3.08 dif. I had a 305, TBI spacer, Edelbrock headers and Flowmaster catback 3" and K&N
I haven't tried my new motor yet for top speed but I get to 120 mph with the t roof off and windows down in the same distance that I did with the old 305. I now have a 350 making approx 300 hp and 375 lbs tq. Maybe this summer I'll try again.
Old Apr 15, 2003 | 01:43 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I topped out my 86 T/A at approx 155mph.
3.27 gears, T5, and Edelbrock carb setup on my 305.
5000rpm in 5th gear.
1992 Trans Am
May 10, 2023 07:19 PM
deracer
Apr 11, 2016 12:04 AM
gta90
Sep 15, 2015 04:00 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
InfinityShade
Aug 22, 2015 08:00 PM
