TO much tire spin... slicks on stock rear?
Old Apr 7, 2003 | 03:02 PM
tomster03's Avatar
Car: 88 ramair grey camaro
Engine: 388 stroker
Transmission: th350
ok here is my problem i have this mildly built motor (388 stroker) in this 3500 pound camaro that i raced yesterday. i have directional cut 245 60 rz 15's on the back. and i got no trackion. it was like 30 degrees out so that dont help but this just sucked it spun off the line and spun when i shifted my auto trans. to 2nd and barked in 3rd. i have a all stock open 3.42 rear in my car and it would run 14.00 at 98mph with 2.85 60 foots my question is if i put sticky slicks on it would it blow apart my rear.... if soo what would go? the axles? i plan to put a posi in but dont have the $$ and i happen to be able to barrow some slicks
Old Apr 7, 2003 | 03:30 PM
chefdan1's Avatar
no. slicks will not blow up your rear. seein as how you have an auto you should be allright. it's the guys with sticks that dorp their clutch at like 3-4000 rpm's that blow their rears.
Old Apr 7, 2003 | 04:24 PM
blue305rs's Avatar
Car: 1989 camaro RS
I have heard that slicks can mess up the rear because when you have tire spin, the power is being dispersed on the ground through the tire spin. When you have a lot of power then you put on the slicks, you dont get the tire spin. The power has to go somewhere and since the tires are not spinning, the rear takes on all the power, and if it is a cheap or weak rear, then i would imagine that the rear would go. im not sure if what i said is 100% correct, it is something i have heard from several people. hope this helps.
Old Apr 7, 2003 | 11:50 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
It is possible to bust a 9 bolt rearend. It is not very easy but it can be done. If you were mid to low 11's I would being thinking about a 10 bolt if you go to the track a lot. It depends on how much you race at the track.
Old Apr 8, 2003 | 12:37 AM
BTS88IROC's Avatar
You mean he needs to go with a 12 bolt if he races alot. You will grenade a stock rear with slicks in no time.
Old Apr 8, 2003 | 02:16 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I meant to say replace the 10 bolt with a 12 bolt. Thanks for catching that BTS88IROC.
Old Apr 8, 2003 | 01:10 PM
tomster03's Avatar
Engine: 388 stroker
Transmission: th350
so slicks a no no on all stock... what is most common to blow axle splins? or ring gear, spider gears?
Old Apr 8, 2003 | 01:39 PM
Dan88IrocZ's Avatar
Try some street legal drag radials. Plenty of bite, but not TOO much to leave your rear 15 feet behind your dragging & sparking car
Old Apr 8, 2003 | 01:43 PM
tomster03's Avatar
Engine: 388 stroker
Transmission: th350
i moved my tourqe arm could that make a differnce with wheel spin at what level should the front be at i herd the lower (closer to the ground) the front is the more bite? is this true i have to move the mounting point to my new reanfoced crossmember because of the tranny swop
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
