difference between v6 and v8 t5 trannys?
Old Apr 9, 2003 | 04:32 PM
88redthunder's Avatar
Car: 1988 Camaro SC
Engine: 305 TBI
I've been told that the clutch assembly is different for the v6 and v8 t5s, but what exactly is different? I assume it has a different bellhousing, too, but am I correct in that? Any and all help is greatly appreciated.
Old Apr 9, 2003 | 06:59 PM
Car: 1988 Camaro SC
Engine: 305 TBI
ttt
Old Apr 9, 2003 | 07:42 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The bolt pattern on the back of the motor is different, so the BH is different; the bolt pattern on the back of the crank is different, so the flywheel is different; the 6-cyl clutch has 14 splines where the V8 has 26, so the clutch gear ("input shaft") is different; the gear ratios are different, with the 6-cyl having much more widely spaced ratios to allow the car to get out of the hole at least in the same calendar day that the driver lets the clutch out (usually), while the V8 one has closer-spaced ratios so that the engine can stay entirely within its max power band all the time.
Other than that, they're exactly the same.
Formula_88AE
Sep 3, 2015 01:47 PM
WIzmo
Aug 30, 2015 02:30 PM
crazynights
Aug 21, 2015 06:53 AM
TRAXION
Aftermarket Product Review
87
Nov 22, 2008 10:33 PM
CamaroMike
Jul 16, 2001 02:04 PM
