Do I want a high stall speed or a low one?
Old Apr 10, 2003 | 04:21 PM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
I am a bit confused as far as what the lock speeds on a torque converter mean? IE 2400RPM, 2200RPM, etc...? I have done extensisve searches and found some great info on what a torque converter does, but not what the different lock speeds are for? Sorry if this sounds stupid, but does a 2400RPM lock speed mean the car won't move until you hit 2400RPM's?
I am buying a new tranny (pro-built) and I really want to know what the difference is so I can make an informed decision.
PS I am looking for something that will allow me good gas mileage. Looking for 325 FHP and 25mpg, highway. Going ot be using 3.23 gears on a posi rear, pro-built street/strip tranny, and a lightly built TPI vortec 350.
Thanks for any and all responses.
James
Old Apr 10, 2003 | 04:36 PM
Drakar's Avatar
As far as my understanding of Torque converters is, and it is limited in everyway (hoping someone with knowledge will jump in)
The higher the stall speed is used when you want to be in or just a little under your peak torque.
IE if you make 350lb-ft of torque @ 3200 RPM, you would want a stall around 3000 that way you are just under your peak torque, therefore giving max power to the ground for a killer launch (provided you hook up)
hope that helps. and hopefully someone will give you a more detailed explanation or correct me if Im way off.
Old Apr 10, 2003 | 05:46 PM
Engine: 355
What happens to the torque converter when you hit that stall speed? Also does the stall speed have anything to do with mileage at all?
Thanks,
James
Old Apr 10, 2003 | 08:31 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Yank recommends 500-700 less than your torque peak for maximum ET. But like Drakar said "provided you hook up". I just bought a 2800 stall for my 305 which peaks @3400.
jklein337
Sep 19, 2018 06:23 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Jake_92RS
Aug 17, 2015 09:42 AM
perZ
Aug 15, 2015 01:17 PM
